This may be a stupid question, but ive just got a cone filter for my 998 and i cant see how it will fit.
Does it just swap with the old one ? or is there a bracket i need to get ?
thanks
Fitting Cone Filter
Aaron_Gardner
, May 17 2009 06:41 PM
4 replies to this topic
Posted 17 May 2009 - 06:41 PM
Posted 17 May 2009 - 07:18 PM
youll have to remove the elbow the old filter sits on
Posted 17 May 2009 - 07:21 PM
yeh remove the elbow and then , take the bolt off the middle of the k&n filter, then using the rubber gasket attach to the car and then rettach the 2 screws, then refit the filter and look at the improvement
Posted 17 May 2009 - 07:23 PM
youll have to adjust the mixture and possible get a new carb needle aswell
Posted 17 May 2009 - 07:26 PM
yeh idealy u need a new needle, spring and then reset the fueling
and make sure u dont turn the carb upside down if u take it out as this will possibly result in grit getting into the float needle and stoping it so the carbs over fuels and then makes a puddle of petrol
hahaha yeh i learn the hard way with kevs mayfair DOOH
