Horific Reaction When I Put The High Build Primer On
tractor1
, May 21 2009 09:20 AM
10 replies to this topic
Posted 21 May 2009 - 09:20 AM
Hi All
We had a relativly mild night in the west country last night so i decided to put some high build primer on my mini ready for it to be flatted at the weekend.
the trouble is it had a massive reaction with the etch primer, it's all blistered.
The only thing i can think it may be is that when i put the etch primer on i forgot to use the thinners that came with it i just used standard thinners and so when i put the high build on the same standard thinners melted the etch primer below.
could it be something as simple as that?
i bought all the paint from the same guy who assured me it was all compatable with the final cellulouse top coat.
does the thinners that come with the etch primer have a special hardener in it or something?
Posted 21 May 2009 - 01:38 PM
I had a reaction with my high build primer. Bubbled up around the edge of my roof. I think it was a little wet in that area after some wet and dry work. Could this be the problem with yours.
Posted 21 May 2009 - 02:09 PM
yeah mine looks like that
perhaps i didn't leave it long enogh to set then, i sprayed the etch primer on sunday night, and it's been cold and wet ever since so i guess it may not have set
i would say how long shold i leave nut how longs a piece of string beacause i'm not in temperature controlled booth it's weather dependent i guess.
Posted 21 May 2009 - 02:37 PM
Did you put degreaser on the etch primer?
if you did, it probably absorbed a bit and wasnt completely dried out before applying the high build
Paul
Paul
Posted 21 May 2009 - 02:52 PM
ah good shout i ran over the whole body with panel wipe then only left it about 10 mins (or however long it took mix the pimer) i'll leave it a bit longer next time just to elimate that possibility.
I've ordered some etch primer so hopefully ill have the old stuff sanded off by the weekend
Posted 21 May 2009 - 03:14 PM
Etch it, leave it 20 mins then high build, dont degrease inbetween.
Paul
Paul
Posted 21 May 2009 - 03:29 PM
ok will do,
the only thing i will ask is should the etch be fully set before i spray h/b over the top or does it not matter?
the reason i ask is because i'm not in a controlled room so it might take up 2 an hour or so to fully set which is ok but if it doesn't matter that the etch is fully set then i won't stand around for ages watching it dry!!
tractor
tractor
Posted 21 May 2009 - 03:41 PM
buy your self a heat gun and use it, the best tool for body work and painting.
Posted 21 May 2009 - 05:09 PM
personaly i wouldn't force dry the etch and primer you could aid it by blowing air across it with the spraygun just to get it moving and the solvent away from the panel. but dont go mad as you dont want it to skin over and trap the solvent in. If it were water based top/colour coat paints then a heat gun is a great idea looks like the solvent from the new coat has got under the other pain and wrinkled it
Posted 21 May 2009 - 05:39 PM
i wonder why paint shops put the cars with new primer on into the oven.
Posted 29 May 2009 - 11:27 AM
Hi All
just to let you know for future reference the reation happend in this case because of a combination of things mainly because i've never used the correct thinners with the etch primmer and so the etch didn't set off hard so the cellulouse high build thinner got underneath and blistered the paint.
i've just resprayed the etch primer but this time using the correct thinners but also heating the pannels up to arround 24'C so it baked off in around 2o mins, then i put on two coats of high build with no reactions at all, i've left that to fully cure for a few days now so i'll rubb it down and spray the top coat this weekend.
