Cam Follower Problem
5 replies to this topic
#1 stardude
stardude
  • 2,457 posts
  • Local Club: hilltop mini's
Posted 23 May 2009 - 07:51 PM
hiya
after changing my head gasket and starting the engine a few seconds later, as started backfiring out of the carb and sounding realy nasty.
i took the rocker cover off, and the number2 exhaust pushrod had dropped by about an inch and was flapping around.
i have a feeling that the cam follower may have broken or something else?
what could have happened??
cheers
adam
#2 dlm
dlm
  • 175 posts
Posted 23 May 2009 - 08:02 PM
hiya
cheers
adam
I think you may have pulled a cam follower out when you removed the push rods. You may get away with removing the tappet cover and refitting the cam follower, but you may have damaged the camshaft lobe and bent the push rod.
Edited by dlm, 23 May 2009 - 08:04 PM.
#3 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 23 May 2009 - 09:21 PM
Basic small bore fail! you can take the covers off to see if you have f%%%ked the camshaft and parts, if not and you see no damage put the cam follower back. be prepared for the worst.
#4 mikko
mikko
  • 119 posts
Posted 23 May 2009 - 09:40 PM
i'll give a standard cam for postage cost and 10 smokes if ya want, they're a gift to change, did my first cam change a few months back after thinking for ages is was gonna be difficult to do.
#5 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 23 May 2009 - 09:41 PM
i did this recently on a custoemers car.
removed the pushrod by compressing the valve with a suitable screwdriver, relocated the cam follower, re-inserted the pushrod, released the valvespring and re-adjusted tappets.
i got away with it ...........
#6 stardude
stardude
  • 2,457 posts
Posted 24 May 2009 - 06:26 AM
ah, i dont realy care if its screwed realy, as i was due to to beswapping my engine next week anyway lol.
it has just gone around the block and the bores are like looking into a mirror! lol
the wholeengine was about to die anyway.
its being recovered home today anyway, then the engine change begins
