Now, it's all done and finished and working and I'm sharing the photo's in case they help or inspire anyone of you.
Hope you likey
This is the passenger side door pocket I've used from a Mark 1 Metro. They are very very nearly the same as the Mini pocket with the shape and hole alignment but not quite. Good enough though. Here I've given it 4 coats of plastic primer and 5 coats of matt black paint.
This is the inside of the door pocket (obviously
Here's the wiring in situ. I've used the tailgate gaitors from an MG Metro to house and protect the wires (top TMF tip
Here are the wires again, utilising an existing gromet and hole in the body behind the carpet.
Here it is, plumbed in and fitted. Personally I think it's quite a subtle front speaker install.
Here's my JVC KD-NX5000 installed in my new Sportspack dash. The head unit is a CD/Tuner/DVD/Sat-Nav unit all-in-one. The Sat-Nav antenna is just a small 1" square by 1/4" box that sits on top of the dash, right up against the glass, and is barely noticable. Incidentally, I bought this unit over a year ago, and it's taken this long to get everything else ready to install it
You can also see the secondaty interior light I've fitted in place of the ash tray. It was a 5 quid purchase from ebay and I think it might have come from another Rover, but was being advertised as being an ash tray replacement, and it really isn't a bad fit at all. I've wired it so that it's 'off' when 'rocked' upwards, 'on' with the door switch when in the middle and 'on' permanently when 'rocked' downwards.
Here's the glove box. Again, I've lined it with a thin automotive carpet and fitted a standard (later) Mini interior light in the back (if you've got an MPi dash in you car, you'll see a rectangle inside (where mine is fitted) where the interior light is fitted as standard on jap spec cars). I've also fitted a fag lighter socket (for phone charger, not faglighter) and wired in the light for it, and the interior, to the side lights.
Now it's all working, sat nav (which has caused me a bit of grief) and pleased as the proverbial punch
Hope you like it and it's of interest to you
