R1 Drive Flange Width
8 replies to this topic
#1 SukiDawg
SukiDawg
  • 304 posts
Posted 25 May 2009 - 12:03 PM
Hi All,
I posted this in the main questions area of the forum but don't seem to be getting any response.
Does anyone know - or can they measure - the width of an R1 propshaft drive flange for me? I know someone on the forum sells the, as I've seen it in the signature at the bottom of their posts... unfortunately I can't remember who it was... Its the distance from the back face of the flange (where it sits against the output shaft of the bike) and the face the propshaft flange bolts to...
Its to I can detail this area of my CAD model to determine an accurate prop length...
Thanks in advance,
David.
#2 R1mini
R1mini
  • 1,387 posts
Posted 26 May 2009 - 11:05 AM
I have one for sale £30 plus postage, if I can find it I will measure it, depending on who made it will give you different measurements
David
#3 Kraig
Kraig
  • 26 posts
  • Local Club: None
Posted 26 May 2009 - 11:58 PM
Just curious, are you adding a guibo to absorb driveline shock?
#4 R1mini
R1mini
  • 1,387 posts
Posted 27 May 2009 - 08:59 PM
Put your hand in your pocket
David
Edited by R1mini, 02 June 2009 - 06:06 PM.
#5 SukiDawg
SukiDawg
  • 304 posts
Posted 28 May 2009 - 09:52 AM
I'm going to use a TRT compliant propshaft fom Baily Morris (propshaft manufacturers). Its what the BE kit car guys use...
As for the flange, someone was already good enough to measure one for me - but another data point can only help. Can you measure your's R1 mini? I'm not needing one right now until I'm a bit further into things...
Cheers...
#6 R1mini
R1mini
  • 1,387 posts
Posted 28 May 2009 - 11:30 AM
No problem, I will measure it, but like I say it will be different depending on who makes it, I will sort it tonight
David
#7 R1mini
R1mini
  • 1,387 posts
Posted 02 June 2009 - 06:06 PM
28mm depth
David
#8 mika
mika
  • 51 posts
  • Local Club: south lakes
Posted 03 June 2009 - 09:00 PM
hi i am amazed at your cad work any chance of a copy of it i am also building a full spaceframe its in the zcars bit
#9 SukiDawg
SukiDawg
  • 304 posts
Posted 04 June 2009 - 06:39 AM
Thanks David.... Seems they are all about "an inch and a bit" and as the prop will be made specially to suit thats close enough for now. Gives me a ball park length to put the centre joint in the correct place (needs to be within 100mm of the prop centre according to the manufacturers).
David.
