Mowog ?
10 replies to this topic
#1 stevo-1991
stevo-1991
  • 227 posts
Posted 26 May 2009 - 09:36 PM
hi everyone i was wondering if anyone could just tell me what mowog stands for as i have a engine with parts stamped with mowog on. Are they old performance parts from back in the day or just casting marks or where they on specif engines like coopers etc ?
thanks steve
#2 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 26 May 2009 - 09:38 PM
Morris-Wolesley Garages
Was stamped on original factory parts I believe
#3 stevo-1991
stevo-1991
  • 227 posts
Posted 26 May 2009 - 09:44 PM
so the parts i have on my engine may be orginal parts from when the engine was made ? any idea when they stopped making mowog parts ?
thank you for the quick reply
#4 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 26 May 2009 - 09:48 PM
Most likely the parts are original,
I'm not too sure when the stamping/marking stopped, I would guess that they would have been marked right up till the end of production?
#5 stevo-1991
stevo-1991
  • 227 posts
Posted 26 May 2009 - 09:51 PM
okey dokey thanks for the help :)
#6 newdawn1st
newdawn1st
  • 1,268 posts
  • Local Club: Fylde Mini Club
Mowog was an 800lb gorilla employed by BL to tighten up the flywheel bolts using a large wrench and a length of scaffold pole. Apparently :)
#7 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 26 May 2009 - 09:52 PM
Mowog was an 800lb gorilla employed by BL to tighten up the flywheel bolts using a large wrench and a length of scaffold pole. Apparently :-
They never fed him his Bananas which sent him Ape :-
(Badoom tish!)
#8 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 27 May 2009 - 09:28 PM
MOWOG is MOrris WOlseley Group (not garages)
Its found on most castings on early Minis.
#9 stevo-1991
stevo-1991
  • 227 posts
Posted 27 May 2009 - 09:32 PM
im trying to roughly date a engine i have been given it has no cylinder head marks as it has been re bored to 1400 or 1380 i am unsure . but most parts have mowog stamped on them what sort of year do you think it could be ? did they do mowog parts to a certain year or where they made from 1959 to 2000 ?
thanks steve
#10 62S
62S
  • 1,243 posts
Posted 27 May 2009 - 10:01 PM
MOWOG seems to have started disappearing from parts in the 1980's - probablyw hen the original tooling was replaced as it wore out.
The casting number in the back of the block is a reasonable clue as to age - 12G 1279 was non S 1300 block from 1967 > 1980.
#11 stevo-1991
stevo-1991
  • 227 posts
Posted 27 May 2009 - 10:41 PM
okey dokey thanks for the information if i have no luck i will upload some pictures tommorow for everyone to have a bonder at & try figure out what it was orginally because to me it just seems to be a frankenstain engine haha
steve
