Throttle Cable Bit
14 replies to this topic
#1 finch661
finch661
  • 2,339 posts
Posted 27 May 2009 - 02:40 PM
i have managed to shear the bolt thingy that the throttle cable attaches to (on the carb), anyone know of a bodge repair just so i can get to my mechanics (not going to the mechanics for that, but he will have spare bits for me)
thanks
#2 Grayedout
Grayedout
  • 901 posts
Posted 27 May 2009 - 02:48 PM
If you can get the bolt out then poke the cable through the hole where the bolt was and then just clamp an electrical cholocate box on the cable at the back side of the hole.
#3 finch661
finch661
  • 2,339 posts
Posted 27 May 2009 - 02:51 PM
cholocate box?
#4 Doodling
Doodling
    Formally known as phil.lingard
  • 260 posts
Posted 27 May 2009 - 02:56 PM
i think he meant these. There used to connect electric wire together. From any hardware shop.
#5 finch661
finch661
  • 2,339 posts
Posted 27 May 2009 - 03:01 PM
ah gotcha, i have never heard of them being called that before :dontgetit:
#6 Boycie
Boycie
  • 1,978 posts
Posted 27 May 2009 - 03:10 PM
We always called them chocolate blocks, not chocolate boxes :dontgetit:
#7 91neon
91neon
  • 447 posts
  • Local Club: abingdon owners club
Posted 27 May 2009 - 03:17 PM
replacing the whole cable is a piece of cake take ten minutes
#8 Boycie
Boycie
  • 1,978 posts
Posted 27 May 2009 - 03:18 PM
Yeah but he needs to get the car driving to get one!
#9 finch661
finch661
  • 2,339 posts
Posted 27 May 2009 - 04:08 PM
the cable is fine, its the carb connector thingy thats goosed!
#10 Doodling
Doodling
  • 260 posts
Posted 27 May 2009 - 04:11 PM
I've always called them chock blocks unless it's a electricians thing?
Will the cable go through the throttle housing.
Edited by phil.lingard, 27 May 2009 - 04:13 PM.
#11 Big_Adam
Big_Adam
  • 7,435 posts
Posted 27 May 2009 - 04:14 PM
If you have no choc-block then take an old 3 pin plug. Take one of the shoter legs out, chop off the leg and you have a block with a hole and screw.
Same thing, no travel.
#12 Doodling
Doodling
  • 260 posts
Posted 27 May 2009 - 04:17 PM
NICE IDEA
#13 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 27 May 2009 - 04:22 PM
I cut a groove out of a large washer, placed it behind, then tied a stiff wire around it using the groove to hold it in place. Still going strong 5000 miles later.
#14 91neon
91neon
  • 447 posts
Posted 27 May 2009 - 06:37 PM
ok my bad i forgot that when mine went i had a spare. you need to buy a solderless nipple its what that bolt thingy is called mate
#15 finch661
finch661
  • 2,339 posts
Posted 27 May 2009 - 09:41 PM
cheers everyone, i managed to use a block connector and it seems ok (for a temp job). i will let you know if i break down!
