Wheel Bearing
Posted 30 May 2009 - 02:26 PM
Year:1988
im just doing one of my wheel bearings on the front and just strugling getting the hub off i dont understand how it explains in the haynes manual about removing the top arm from the hub
any help much apricated
thanks mark
Posted 30 May 2009 - 03:23 PM
Posted 30 May 2009 - 04:17 PM
Undo the drive shaft retaining nut after removing the split pin.
Remove the brake caliper attachment bolts - they are 9/16" A/F
Undo the track rod end and, with a ball-pin splitter, break the joint.
Undo and remove the top and bottom swivel pin nuts
Use the spiltter tool to break out both of those joints.
Leaving the drive-shaft in situ (you may have to tap the end of the shaft with a wooden of copper mallet - not a big hammer in order to free it off) remove the hub from the car.
Then you can remove the wheel bearings.
Don't forgett eh spacer and seals when fitting the new bearings
Don't forget the rubber swivel pin caps when replacinh the hubs into the car. Feed the drive shaft through and lightly fit the big drive shaft nut before engaging the swivel pins into the upper and lower arms.
Do the drive shaft nut up very tight. If you have one, use a big flat plain washer under the drive shaft nut first to ensure that it pulls right up, then take the nut off and re-fit with the taper washer. This nut does need to be very tight. Check wheel rotation before lowering thecar onto the ground to drive it.
I don't think I've missed anything and I hope this helps.
Posted 30 May 2009 - 04:53 PM
thanks mark
Posted 30 May 2009 - 06:22 PM
thanks for the help but i have had to put it all back together and try another day all seemed to be gin well an fairly easy once i knew what i was doin but the bottom ball joint wont move at all and im not using a cheap ball joint spliter iether try hammer on it and everythink and wont move at all any ideas will be great
thanks mark
Get a bigger hammer. I use a lump hammer and really swing at the forks, but make sure they are not just going up on the hub, make sure they have room to move out.
Posted 30 May 2009 - 06:24 PM
Don't hit the top though, it will squash the thread and ruin your ball joint.
Posted 30 May 2009 - 07:12 PM
Posted 30 May 2009 - 07:18 PM
Posted 31 May 2009 - 04:52 PM
