Help Flickering Brake Warning Light When Braking
6 replies to this topic
#1 longbridge4life
longbridge4life
  • 159 posts
Posted 01 June 2009 - 10:07 AM
Hi all i need some advice,
Ive a 1989 mini thirty
Im having problems with my brake warning light rocker switch in the centre console.When i start the engine it remains not lite,If i push the brake warning light the light comes on to prove the circuit so all is good.My problem comes only when braking,When i brake the light flickers at first and then lights up solid as i come to a stand still,When i release the brakes the light turns off.
Now the reservoir fluid level is in the middle between min and max and hasnt needed topping up since i got the car,The only thing ive done in the last few weeks is replace the rear drum shoes.
So in a nut shell the light only comes on when braking starting with a flickering light then becomes solid until brake released.Ive stripped the reservoir cap and cleaned the contacts up they looked ok.
Any advice would be great :crazy:
#2 MRA
MRA
  • 7,607 posts
Posted 01 June 2009 - 10:19 AM
Does the pedal go down quite a long way ?
#3 mars red mike
mars red mike
  • 1,500 posts
Posted 01 June 2009 - 10:21 AM
Top the fluid up to max. When you push the brake pedal the fluid level will drop in the reservoir causing the light to come on.
#4 longbridge4life
longbridge4life
  • 159 posts
Posted 01 June 2009 - 10:30 AM
hiya no the pedal feels normal,it doesnt travel all the way due and has nice resistance when being pushed
#5 longbridge4life
longbridge4life
  • 159 posts
Posted 01 June 2009 - 10:32 AM
ahh i see what you mean,So top it up to max,its filled to medium at the moment(dot 4 fluid) shame its doing this at only medium level fluid ill give it a whirl
#6 BoboGib
BoboGib
    RoboGimp
  • 1,579 posts
  • Local Club: SMAC
Posted 01 June 2009 - 11:10 AM
While topping the fluid up might sound like the easiest way to solve the problem, make sure you give your brakes a check over/get them checked over to make sure that the pads or shoes don't need replacing. As Pads wear down the piston in the caliper moves further and further out meaning all the fluid that was in your reservior is now behind the piston in the caliper.
#7 longbridge4life
longbridge4life
  • 159 posts
Posted 12 June 2009 - 01:52 PM
UPDATE>>>>>>
I took apart the reservoir cap and cleaned all the spade connections and generally serviced it,Didnt look to scaled up.But since doing that its been perfect no more flickering light on braking :) thanks to all for your tips and advice
