Mot Question
Posted 02 June 2009 - 04:45 PM
Now it is a ford heated screen and will probably cost more to replace then the car is worth and I want to replace the car at the end of the year so do not want to spend money on it unless I have to.
Before I put it in for it's MOT does anyone know if this is a MOT failure.
Many thanks
Steve.
Posted 02 June 2009 - 04:55 PM
On modern cars the windscreen is part of the structure, plus all it needs is a pot hole and the whole thing could go, leaving you blind.
Like I say I may be wrong
Regards
David
Posted 02 June 2009 - 05:21 PM
Someone more knowledgeable may tell you different, but, I am sure it is a fail.
Regards
David
DOH I hope you are wrong or car loan here I come !
Posted 02 June 2009 - 05:22 PM
cost you excess of usually around £50-70
Posted 02 June 2009 - 05:51 PM
Posted 02 June 2009 - 06:18 PM
Posted 02 June 2009 - 06:50 PM
If the crack does not enter into the area swept by the wiper blades then it would be pass and advise. Any damage on the nearside of the screen and in the swept area must be able to be contained in a 40mm diameter circle. If the crack just enters this area you might just get away with fitting a slightly smaller wiper blade and hope the tester doesn't notice.
Well just checked and the nearside wiper goes over the crack by about 10mm where the crack sort of loops out and back in again, so I guess that would be a fail or I will just have to ride my luck and see what they say.
Edited by scrumpymini, 02 June 2009 - 06:50 PM.
Posted 02 June 2009 - 07:14 PM
With regards to safety, most cracks will propogate due to flexing of the screen, but as yours has entered and exited the screen it is unlikley to spread further or shatter. This is mainly a matter for your own conscience.
Posted 02 June 2009 - 07:24 PM
Posted 02 June 2009 - 07:56 PM
Wiper blades come in size steps or 1" and all generally have the same fitting. If you change the blade to one 1" smaller you should miss the crack by 3mm. There is no MOT regulation on the size of the wiper blades other than they should clear an area lage enough to give the driver an adequate view of the road. It is very common for owners to accidentally replace wiper blades with ones of an incorrect size.
Thanks for that will buy a short arm and blade, the car is hardly ever used and I just want to hang onto it until the end of the year with the MOT so I can get the 2k trade in.
