Hi,
For my B16A1 Zcars conversion I've reached the 'wiring' part.
problems...... I've started with the loom business which I'm not really that good at..... Choose to use the Honda loom and cut everything out that I don't need. Hopefully did that alright.....
What does the startermotor need to turn over? I've connected the battery, grounds on the engine and connected the starter key. It doesn't work!
What an I missing? What are the start conditions needed before you can start the car? Like, does the fuel pump need to be connected or the radiator fan dashboard ect?????
Any ideas?
Many thanks in advance!
René
Can't Even Get The B16a1 Starter Motor To Turn...
Renessy
, Jun 03 2009 02:29 PM
2 replies to this topic
Posted 03 June 2009 - 02:29 PM
Posted 03 June 2009 - 02:41 PM
to spin the starter motor over you need positive to the solenoid - via a switch. earth from batt to shell, and to engine. and main big cable from batt to starter motor.
that will spin over the engine. it wont start with that though...
have you a cable from the alternator to the starter motor which then goes back to the batt?
good luck
good luck
Posted 03 June 2009 - 05:02 PM
By solenoid you mean the main relay????
No, I have a cable from the alternator to the main relay box, and from the Batt to the starter motor....
René
René
Edited by Renessy, 03 June 2009 - 05:09 PM.
