Third Brake Light
8 replies to this topic
#1 Kernal H
Kernal H
  • 746 posts
Posted 03 June 2009 - 10:15 PM
Sorry to repete the same question, I've been through 10 pages of search results and only got so far as april 2009!
Can I wire in a 3rd brake light into the existing wiring in the rear? Would it overload any of the wiring as to make fuses blow or wiring melt? It'll be a proper light not LED.
#2 The_Mistro
The_Mistro
    Farmer Barley Mow
  • 2,369 posts
Posted 04 June 2009 - 12:25 AM
i have, and i have had no trouble! apart from the scoth blocks being rubbish and not working all the time :D
#3 Kernal H
Kernal H
  • 746 posts
Posted 04 June 2009 - 07:40 PM
Brilliant... Might get round to adding one soon then!
#4 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 04 June 2009 - 10:01 PM
Would LEDs draw less current from the loom and therefore be less of a risk?
I have one but haven't fitted mine yet - not sure if I should.
#5 nicksuth
nicksuth
  • 1,631 posts
Posted 04 June 2009 - 10:10 PM
Worked for me...........
[attachment=85942:DSC00352.JPG]
#6 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 04 June 2009 - 10:14 PM
I take it those are normal bulbs with an LED high level?
#7 nicksuth
nicksuth
  • 1,631 posts
Posted 04 June 2009 - 10:17 PM
Yes, I thought they may have needed lower voltage but appaerntly not (or maybe there's a cheap and cheerful transformer built into the unit?)
#8 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 04 June 2009 - 10:24 PM
I wouldn't have thought so, some fit resistors but unless it states that it needed one, I think u'll be ok (don't forget, you will be loosing a bit of voltage due to the other brake light bulb being fitted).
I have LED rear bulbs (clear lenses) - kind of blinding slightly at night.
#9 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 04 June 2009 - 10:30 PM
Minimag May 2009, 10 minute tech guide on how to fit a high level brake light, if thats any help? Not sure if its LED etc etc
Its the one with Roofless's R1 purple cabrio on the front, just incase you didnt know it? >_<
Hth
