12x4.5 Wheels Rubbing On Rear
7 replies to this topic
#1 DrMcNasty
DrMcNasty
  • 176 posts
  • Local Club: TMF International Member
Posted 05 June 2009 - 06:23 PM
I am looking for some advice on this matter.
I have a set of 12 x 4.5 mini lights I just put on the car and the back tires seem to be rubbing on the shock and the rear tow hook.
I was under the impression that these would fit without a problem but they would be tight.
What should I do? Can I just add in a spacer to the rim and be good? If so how much should I add and still not have to change the normal wheel studs?
Thanks in Advance.
Nasty
#2 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 05 June 2009 - 06:38 PM
are you running standad drums or the later type spacer ones
dave
#3 matty4113
matty4113
  • 118 posts
Posted 05 June 2009 - 07:47 PM
i am interested in this as i am planning on fitting 12x5 minilites and mine has the old type rear drums, would this be a problem? sorry to hijack
#4 DrMcNasty
DrMcNasty
  • 176 posts
Posted 05 June 2009 - 08:14 PM
Standard drums.
It seems from other research that any 12 inch wheel will require longer studs as well as spacers. I have been doing some other reading and this seems to be the general responses I have found. Since the 12 inch wheel only came on cars with front disc brakes the back were spaced out 1 inch to make it even with the front and to allow the extra clearance. So it seems I am going to have to get spacers and longer studs on mine.
Matty,
I would assume the same for yours as well if your going with standard drums and 12 inch wheels.
Nasty
#5 matty4113
matty4113
  • 118 posts
Posted 05 June 2009 - 08:28 PM
many thanks, il get mine swapped
#6 redhotmini
redhotmini
  • 1,607 posts
Posted 05 June 2009 - 10:04 PM
you might find a 5mm spacer shim on the rear will give you the clearance you need, thats what i found on my old clubby which had standard drums all round
#7 daveeeeee
daveeeeee
  • 684 posts
Posted 05 June 2009 - 10:34 PM
Where are you located? Think I've got some 1 inch spacers somewhere you can have for free if you're local to Egham in Surrey. Don't know how much they are to buy. No studs though, threw them out :ermm:
#8 DrMcNasty
DrMcNasty
  • 176 posts
Posted 05 June 2009 - 11:27 PM
I am in Ontario Canada but would be happy to pay the post cost on them if your willing to throw them in a box and send them on over.
I have sent you a PM with information.
