Can You Machine A Dish Into 1275 A+ Pistons
Posted 05 June 2009 - 07:06 PM
if not then are there any pistons availible which i can do this to?
thanks
Posted 05 June 2009 - 08:23 PM
hello, as in the title realy, is it possible to machine a bigger dish into a 1275 A+ pistons to lower comp ratio? i have the higher compression A+ which i think is 9.?:1
thanks
well wouldent it make the metal of the piston alot thinner making it more suseptable to a hole melting through
Posted 05 June 2009 - 08:29 PM
Either that or have the head machined with bigger chambers to lower the CR
Posted 05 June 2009 - 08:46 PM
Posted 05 June 2009 - 09:26 PM
Posted 05 June 2009 - 09:34 PM
trying to avoid a decompression plate because they seem like a bit of a bodge, i may just get the chambers enlarged.
Very sensible
Posted 05 June 2009 - 09:45 PM
J Cooper conversions after 1992 run 10.5-1 but will be marked 12A you will need to check how close the piston comes to the top of the block to tell.
For low boost upto 7 psi the you could use a standard piston with an enlarged head, but the piston would have a limited life span.
The standard pistons such as the 21251 and 21253 arent suitable for re machining, I cant speak for others.
If you are running a serious boost or long life forced induction build then you will need a set of Omegas with a bigger dish
to drop the Compression ratio.
It would also be worth you talking to Hypertec in Australia or the FW Thornton in Shrewsbury to seeif JP make something suitable, as the Omegas are a tad on the expensive side, Avonbar would also be able to advice you.
Good luck on your journey.
Edited by Cooper-202S, 05 June 2009 - 09:47 PM.
Posted 05 June 2009 - 09:55 PM
Go direct to MED if you want Omega pistons. Cheaper and quicker service.
Posted 06 June 2009 - 12:12 PM
the trick i use for machining them is to hold th paiston against the chuck on a lathe using a bar through the gudgen pin hole with a peice of threading goingthrough to the back of the lathe and held there on a bush. then just take the dish out squarer with a tool with a generous radius on it.
Posted 07 June 2009 - 07:48 PM
Posted 07 June 2009 - 09:04 PM
