Rear Seat Enclosure 2x 12inch Subs
Posted 07 June 2009 - 01:13 PM
I need some help and ideas,
1, please post up pictures of your rear seat i installs so i can get some ideas.
2, does anyone know the best size for the box?? the specks of the drivers are on the website below!
3, any majour do's and dont's with rear installs??
http://www.diamondau...manual-2008.pdf
http://www.diamondau..._sheet-2008.pdf
cheers Dudes!!1
Posted 07 June 2009 - 02:35 PM
Posted 07 June 2009 - 03:17 PM
The size of the enclosure for the subs are listed on the spec sheet that you've attached
cant see it mate? it all looks giberish to mee?
Posted 07 June 2009 - 03:23 PM
Sealed: 0.875 ft^3
Vented: 1.25 ft^3
That's per sub.
Posted 08 June 2009 - 04:10 PM
I plan to put 2 Diamond Audio D6 12" Woofers in a double box in the rear of my mini, Im going to lose the back seats. I want to build the biggest box possable to give me the most cubic inch forr the best sound. I also plan to port it.
cheers Dudes!!1
how big of a amp do you have to power the pair of subs?
2.5cubes before port and sub
and i would do between 25-37 sq inch of port, but i would shoot for around 31, it will give you a good mix between
spl and sq
and me myself, i do slot ports over round ports
i could tell you how deep the port needs to be for a tuning but
i would need to know the specs on the box your building
and where you wanted it tuned to
Posted 08 June 2009 - 04:29 PM
Posted 08 June 2009 - 08:36 PM
does the length of the post make a diference???
Posted 08 June 2009 - 09:13 PM
31 sqaure inch of port in the boxcheers dude, you recon i should head for about 31cubic inches inside the box then??
say like 15.5x2 slot port would be 31sq inch of port
i don't think i would make a slot port that skinny tho
but a good rule to follow is 10-15sq inch of port per every cube of air space
and port lenght is how you tune the box to the freq, for daily set up, something around 30-36hz will work fine,
most say 33hz is the sweet spot tune for a female, if you know what i mean, lol
here's a box i built for two type r 12's being powered by 1600watts
Edited by joakwin, 08 June 2009 - 09:22 PM.
Posted 09 June 2009 - 05:40 PM
Posted 09 June 2009 - 05:57 PM
