Seam Sealer, How Do I Remove It ?
13 replies to this topic
#1 buxvan
buxvan
  • 146 posts
Posted 11 June 2009 - 10:04 AM
i am prepping my shell for spraying. i have panelled in the rear side windows of my clubby est to change it into a clubvan. i seam sealed the window frames around the panels due to the small water trap gap. i have got smears of sealer where they shouldn't be. it has been on for a couple of days now. any tips on removing the damn stuff.?
thanks in advance.
#2 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 11 June 2009 - 10:07 AM
if your preping for paint cant you use a fine grit to sand it out?
#3 buxvan
buxvan
  • 146 posts
Posted 11 June 2009 - 10:21 AM
it doesn't want to sand as it is not hard like filler, it still is hard but flexible so sanding isn't working.
#4 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 11 June 2009 - 10:22 AM
umm i see how about heating it up and try pulling it off?
#5 buxvan
buxvan
  • 146 posts
Posted 11 June 2009 - 10:24 AM
its too close to the actual gap that i originally sealed !
#6 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 11 June 2009 - 10:26 AM
sharp knife and be very careful?
#7 BGB
BGB
  • 401 posts
  • Local Club: East Lothian Mini Owners Club
Posted 11 June 2009 - 10:32 AM
if its silicone you can buy remover from B&Q
I have some to remove the silicon some idiot put around the crome arches so when i removed them it left a line 3-4ml thick and loosk auful.
may do it today
#8 buxvan
buxvan
  • 146 posts
Posted 11 June 2009 - 10:37 AM
tried a Stanley blade (nice new one) but no joy, it just wants to dig into my nicely sprayed bondaprima (great paint by the way)
#9 jkjaxor
jkjaxor
  • 331 posts
Posted 11 June 2009 - 11:06 AM
use a hairdryer and a paint scraper, (the one like a spatula,) if its on a flat panel to get it of and leave it smoothe then sand back,
if its not on a flat panel u can get a scraper thats got points to it and scrape it out of the gaps, heers an examplescraper
#10 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 11 June 2009 - 11:40 AM
What sealer is it?
Usually are a PITA to remove once set/dried. So unfortunately you might have to scrape it off somehow and repaint the area.....
#11 buxvan
buxvan
  • 146 posts
Posted 11 June 2009 - 11:50 AM
ITS NORMAL SEAM SEALER (THE STUFF I PRESUME GLUE SNIFFERS WOULD ENJOY !)
#12 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 11 June 2009 - 06:22 PM
Try some white spirit on a rag, try soak it for 10mins then go back and rub it away with the rag.
#13 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 11 June 2009 - 06:51 PM
thinners and paper towel, much easier to mask the areas then pull tap off once sealer is applied
#14 cookie4343
cookie4343
  • 2,257 posts
Posted 11 June 2009 - 07:01 PM
Automotive paint thinners will take the primer straight off, i dont think he wants to do that, so i suggest normal household thinners would be better as it wont damage the primer.
