Clarke 90 Amp Mig Any Good
7 replies to this topic
#1 josh.evans
josh.evans
  • 1,439 posts
Posted 11 June 2009 - 08:25 PM
hi could anyone tell me if this is worth buy a clark 90 amp would be ok to do panel work plug and seam welds?
cheers
josh
#2 MRA
MRA
  • 7,607 posts
Posted 11 June 2009 - 08:59 PM
My first mig welder was a clark EN90 I think ...... it was a gas less unit, very good, worked brilliant but not much use for every day welding :)
#3 Boycie
Boycie
  • 1,978 posts
Posted 11 June 2009 - 10:09 PM
Yup, I have a 90amp Clarke one, use it with gas. It's very good as a starter unit, can be run off any domestic power suply and is easily man enough for bodywork thickness metal.
Also, Clarke wire feeders are good, unlike most budget ones.
#4 wolfie
wolfie
  • 1,149 posts
Posted 11 June 2009 - 10:12 PM
the 90 amp is good as it goes down to 25 amps the lowest in the range and perfect to bodywork, stay away from gassless though its s***
#5 MRA
MRA
  • 7,607 posts
Posted 12 June 2009 - 08:57 AM
I had a lot of success with my gasless..... don't diss the gasless :) the main benefits to me where that all of my welding had to be done outside, and the gasless flux doesn't blow away so easily :shifty: I had hired a gas type mig welder it cost a fortune in gas :lol:
I now use Argoshield 5% with a Murex Mig welder and its good for what i do :)
Regards Martin
#6 wolfie
wolfie
  • 1,149 posts
Posted 12 June 2009 - 09:10 AM
gasless is not good for sheet metal and the splatter is quite high so its not an option as far as i am concerned
for good welder advice try searching http://www.mig-weldi...forum/index.php
I dont see renting a bottle of argoshield for a year against the overpriced flux mig wire an issue not with the quality of gasless anyway
murex is rebranded ESAB good welders to
Edited by wolfie, 12 June 2009 - 09:13 AM.
#7 MRA
MRA
  • 7,607 posts
Posted 12 June 2009 - 09:35 AM
In those days I had the little bottles from Halfords etc.... way way to expensive :) ....... you are right a years rent for a bottle + delivery + gas is much better than gasless, however from an enthusiasts point of view gasless has a few advantages.... if you have wire then it should work :) if they are only using it to weld up the MOT each year then a years rent is expensive :lol: as are two dozen of those little bottles :shifty: also due to the slightly larger wire size (flux cored) it tends to reduce your liner wear rate to a manageable level :)
My personal choice is a good quality welder and a 5% argon CO2 mixture in a decent size bottle :)
Regards Martin
#8 just_st3v3n
just_st3v3n
  • 90 posts
Posted 12 June 2009 - 10:06 AM
i have one of these!!
its doing the job for my restoration, the settings can be a bit awkward to get right tho but all in all a good welder imo.
