Engine Temperature Sensor
11 replies to this topic
#1 forehead
forehead
  • 12 posts
Posted 12 June 2009 - 09:08 PM
We have just bought a 1985 Mini fitted with what we think is a 1985 Metro 1275 not an MG engine bearing engine number 12HAC(or 0)8AA******
The puzzle is that it does not appear to have the temp sensor fitted in the std position in the block
Attached File  Image018.jpg   363.05K   21 downloads
This hole is not drilled through and doesn't appear to ever have been tapped or had anything fitted into it.
Can anyone suggest where the temperature sensor might have been fitted or somewhere a new one could be fitted now.
Many thanks.
Edited by forehead, 12 June 2009 - 09:08 PM.
#2 Asphalt
Asphalt
  • 2,173 posts
Posted 12 June 2009 - 09:25 PM
SPI head... They had the sensor fited to the inlet manifold :P Good thing is: it's unleaded.
I guess the heater take off (on head, driver's side) is closed too?
#3 forehead
forehead
  • 12 posts
Posted 12 June 2009 - 09:36 PM
Pardon the ignorance I know a little about Minis but not a lot.
SPI head would suggest we are looking at a newer head on an older block. Is there any identification I could look for on the head to confirm this?
The car is fitted with separate inlet and ehaust manifolds - the inlet appears to be a water cooled Mini Spares unit with the exhaust an LCB?
I had thought the engine had simply been lifted straight out of a Metro however given what you are saying someone has spent a little time upgrading it?
Edited by forehead, 12 June 2009 - 09:37 PM.
#4 DaveRob
DaveRob
  • 703 posts
Posted 13 June 2009 - 06:23 AM
As Asphalt says the SPi head has no temp sensor fitting as the SPi used a coolant temperature sensor under the inlet manifold..... also the heater take off on left side is blanked and their wont be any bypass hose either..... the head for the SPi is labled as 12G940.... but then so are a lot of later 1275 heads including the metro ones... so its more a case of what have you got?...... a few more photos of the engine and the head without the rocker cover would help..... if you want to know that is....lol
Rob
#5 forehead
forehead
  • 12 posts
Posted 13 June 2009 - 06:22 PM
Rob
Attached File  Image019.jpg   439.53K   18 downloads
Attached File  Image021.jpg   404.49K   12 downloads
Attached File  Image022.jpg   450.94K   14 downloads
Attached File  Image023.jpg   453.95K   17 downloads
My mechaninc reckons there is a bypass hose next to the rad by the fuel pump?
The head has the number 12G8403 on it
As you can see the heater take off is in use but the bolts look non-original so have possibley been bodged.
As the suggestion is that this head will take unleaded that would be an interesting thing to clear up.
Many thanks
#6 forehead
forehead
  • 12 posts
Posted 13 June 2009 - 09:14 PM
No one got any ideas?
Problem is unless we know what we are dealing with we dont even know what the correct timing would be or even if we can run unleaded fuel.
#7 DaveRob
DaveRob
  • 703 posts
Posted 14 June 2009 - 06:53 AM
If you look at Guessworks engine number determinator it identifies your engine as
Metro Economy
Engine type & CC : A+ 1275 cc Transverse mounted
Engine features : Lucas 16AC alternator with -ve Earth
1st Alternative compression ratio
Mechanical petrol pump
Gearbox features : Std. Ratio Rod Change gearbox with Pot Joints
3.105:1 Final Drive
Additionally you apear to have a verto clutch, suggesting a later type power unit ( as would be expected from the above info ) BUT your engine does not look standard.... for instance.... in one of the photos their is something that looks like a variable oil pressure release valve... The inlet manifold is certainly non standard.... 12G8403 is not a number in any of my reference books...... and at this era I would expect the head casting number to be 12G940. To have no temp guage thread and still have a bypass hose, if you definatly have one, is very odd........ My thoughts are this engine is a mix of different products.... the only way to be certain what it is and if you have an unleaded head, would be to take it apart and have a look at all the components and find out what other mods have been done..... by the way.... 12G940 would be cast into the head under the rocker cover....
Just my thoughts tho
Rob :cry:
#8 forehead
forehead
  • 12 posts
Posted 17 June 2009 - 03:17 PM
Metro Economy
3.105:1 Final Drive
Rob :)
Hi Rob
Have rechecked the number under the rocker cover and must admit that does look like 12G940. That being the case are we safe to assume the head is off a later Metro and as such unleaded compatible? Its no biggie to run a LRP if we need to - would this harm an unleaded engine if we do?
We have done some tuning work on the engine assuming it was a standard 1275 from an 83 Metro HLE, would the timing be the same for the SPI engine or will that need altering?
Any thoughts where we could relocate the temperature sender given the Mini Spares inlet manifold fitted currently?
Thanks for the assist.
:ermm:
#9 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 17 June 2009 - 03:42 PM
surley u could drill and tap the inlet manifold and fit the temp sender unit there and then link it up to the heater matric pipes :ermm: thats my solution
althought i know tapping aluminum is difficult or you could surely get a thermostat spacer plate and fit it there
or get a universal link pipe with sender unit hole and then cut on of the hoses and fit the sender there :)
http://cgi.ebay.co.u...bayphotohosting
#10 Darkscamp
Darkscamp
    Drives the 'Thing'
  • 1,475 posts
  • Local Club: Nottsaboutminis
Posted 17 June 2009 - 04:45 PM
surley u could drill and tap the inlet manifold and fit the temp sender unit there and then link it up to the heater matric pipes :) thats my solution
that link is for an oil temp sender, not a water one :ermm:
i'm sure i have seen this before and i believe some had the temp sender fitted into the thermostat housing, if it was an spi head there should be a blank spacer block underneath the thermostat housing.
http://www.minispare...itle=THERMOSTAT HOUSING COOPER...
Edited by Darkscamp, 17 June 2009 - 04:49 PM.
#11 mini_turbo_pete
mini_turbo_pete
  • 1,101 posts
Posted 17 June 2009 - 11:11 PM
or get a universal link pipe with sender unit hole and then cut on of the hoses and fit the sender there :P
Have you read the top of this section "Don't give out incorrect advice - if you don't know the answer, don't post!"
The temp sensor needs to be as close to the hot side of the thermostat as possible, putting it on the inlet manifold will give you the wrong readings.
Tapping Aluminium is easier than tapping steel as it's softer!!
#12 forehead
forehead
  • 12 posts
Posted 19 June 2009 - 01:23 PM
surley u could drill and tap the inlet manifold and fit the temp sender unit there and then link it up to the heater matric pipes :lol: thats my solution
or get a universal link pipe with sender unit hole and then cut on of the hoses and fit the sender there :thumbsup:
thanks for all your replies.
Does anybody know what the timing setting would be on this engine?
appreciate all the help
