"topping" S/c Drop Gears
8 replies to this topic
#1 colinu
colinu
  • 517 posts
  • Local Club: MOASF
Posted 15 June 2009 - 11:42 AM
Folks,
As much as I love the whine of my straight cut drop gears, it would be nice if they were just a little bit quiter (especially as I have the prospect of a 600 mile drive next month!). I read an article ages ago where a guy had his drop gears "topped"... a few thou taken off the ends of the teeth which made them a lot quieter. Has anyone here had that done? Does it reduce noise much? Any idea how many thou should be removed?
Cheers,
Colin.
#2 Ethel
  • 26,073 posts
Posted 15 June 2009 - 01:58 PM
I've not heard of it being done to transfer gears.
It was a fix for noisy gearboxes: if the peak of one gear "bottoms out" in the trough between the peaks on the other gear it will try and push the 2 gears apart.
You'd need to grind them, gears are hard.
#3 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 15 June 2009 - 02:44 PM
The drop gears dont bottom out so it wouldnt help
Paul
#4 Cooperman
  • 23,326 posts
Posted 15 June 2009 - 02:54 PM
Straight cut drop gears are really only meant for competition cars as they are just so noisy. I won't drive mine far on the road unless I have to and then I wear earplugs. I try to take it to events on my trailer. It wasn't quite so bad when it was just a SC gearbox, but after stripping the teeth on the transfer gear on a rally I decided to change to SC drops as well. It's a horrendous noise.
#5 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 15 June 2009 - 03:38 PM
But I love it, especially with my semi SC CWP
Paul
#6 Ethel
  • 26,073 posts
Posted 15 June 2009 - 03:54 PM
Every time this comes up I have to ask why no one has made a taper roller idler gear for helical gears :thumbsup:
If anyone is man enough to machine the centre out of an idler I'd even volunteer to be the guinea pig.
#7 colinu
colinu
  • 517 posts
  • Local Club: MOASF
Posted 15 June 2009 - 04:23 PM
Folks,
Thanks for the replies. Looks like I can get a set of standard/helical drop gears from a mate... and as he said "If the drop gear teeth are bottoming out then noise is going to be the least of your probems - horrendous wear and spectacular failure!".
Cheers,
Colin.
P.S.
I'll keep the s/c drops tucked away... "just in case" :thumbsup:
#8 mini13
mini13
  • 3,811 posts
Posted 15 June 2009 - 05:26 PM
they arnt that noisy,
i have no carpet or soundproofing in my car, my mrs slept quite happily on the way back from the l2b on the motorway.
#9 Cooperman
  • 23,326 posts
Posted 15 June 2009 - 07:02 PM
I have carpets, but no soundproofing. I have SC box and drops, a 3.9 final drive, 10" wheels, twin 1.5 H4's and a twin box RC40 exhaust system. Since I suffer from tinitus, I do wear earplugs whenever possible when driving it. It's a seriously quick and successful Historic rally Car, but the noise inside is horrendous except when wearing helmets or using ear plugs.
