My friend has a 998 mini, which struggles to start. In the event that it does start it will run for approximately 10 seconds then cut out, and if the throttle is pressed it will immediately cut out.
I am pretty sure that it will be nothing to do with the mixture as it used to run fine, and the carburetor wasn't fiddled with, the problem occurred after the vehicle being stood for approximately a week.
Hopefully someone could spread some light on this problem
Kind regards Alex
Sorry i place this in the wrong section. Is now in the tech section. Very sorry!!!!!
Edited by baileyboi_01, 16 June 2009 - 10:38 PM.
