Fast Road City E
#226
Posted 04 February 2010 - 06:48 PM
#227
Posted 04 February 2010 - 07:31 PM
#228
Posted 04 February 2010 - 07:36 PM
#229
Posted 05 February 2010 - 10:23 AM
It's not all doom and gloom though because it's pretty basic stuff what she has failed on:
Offside side repeater not working - new bulb.
Both CV joint gaiter split - new cv joint gaiter.
Excessive CO emissions (4.33% when it should be 3.5) - Turn the mixture down a bit.
Offside front brake is binding - bleed front brake.
I did get some advisories though (again nothing to get het-up about):
Both offside tyres are worn - get new tyres
Rear wheel bearing has slight play - fit a new wheel bearing
So all in all, it wasn't really a bad MOt consaidering. He said she's structurally very sound which is what i wanted to hear really.
Cheers,
Andrew
#230
Posted 05 February 2010 - 01:00 PM
#231
Posted 05 February 2010 - 01:07 PM
#232
Posted 07 February 2010 - 12:46 PM
The strip light worked a treat aswell
Is this the mixture screw on my carb? It's a HIF38 but i'm not sure where the screw is:
Cheers,
Andrew
Edited by AndrewJ530, 07 February 2010 - 12:46 PM.
#233
Posted 07 February 2010 - 01:07 PM
#234
Posted 07 February 2010 - 02:04 PM
#235
Posted 07 February 2010 - 02:51 PM
Gives so much light it's brilliant. Cheers Ben. Which way do i turn it to weaken the mixture off?
Screw in too create a richer mixture
and obviously screw out to lean out the mixture.
#236
Posted 07 February 2010 - 03:15 PM
Cheers,
Andrew
#237
Posted 07 February 2010 - 03:19 PM
Cheers mate, i'll screw it out a couple of turns and take it back for the mot.
Cheers,
Andrew
Give it the beans on the way there aswell! Just make sure it's not too lean and going too run too hot.
#238
Posted 07 February 2010 - 03:29 PM
#239
Posted 10 February 2010 - 04:26 PM
I'm going round there tomorrow to set it back properly to about 4% so she should be running sweet by tomorrow night
Andrew
#240
Posted 28 February 2010 - 10:06 PM
Now for a another problem...NEVER PRESSURE WASHER A MINI!
This is the result of pressure washering a mini and leaving the area exposed for about 2 weeks:
With the bumper off so i could see the full extent of the damage:
I know it doesn't look like much but i'm glad i've caught it like it is because this could have gotten a lot worse, very soon.
Thanks to my dad, i have a nice, freshly painted bumper lip (i forgot to get pictures with the bumper off after i'd cleaned it up):
In the last picture i think you can see where he's tidied up the bit next to the indicator where it got scratched taking the grill off before. Hopefully this should keep the rust at bay a little longer.
Cheers,
Andrew
