Fast Road City E
319 replies to this topic
#301 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 25 July 2010 - 06:07 PM
The spec on the Works Rally engine, obviously changed from rally to rally and class to class, but we'll take a list from the Gp. 2 German Rally
The Specification - Roughly
BLOCK
Surface Skimmed to 10thou off piston crown
Over Bore +20 thou
Honed
Chemical Clean
New Cam Bearings Fitted
PISTONS, CRANK AND RODS
Balanced cross drilled
Rods lined up and balanced
Pistons +20 thou with hole drilled for oil in boss
Sprockets on cam and crank, lightened and lined up correctly
CAMSHAFT AND VALVE TRAIN
649 Camshaft (AEA648)
Cooper S Rocker assembly
CYLINDER HEAD AND FUELING
12.6 to 1 compression ratio
Cooper S head (Inlet modified)
Twin 1 1/2 Inch Carburettors
float chamber extended
B.G Needle
Downton Induction kit
GEARBOX
Straight Cut Close Ratio
4.26 Final Drive
CLUTCH
Lightened Balanced Fly Wheel and Backplate
Orange Rally Spec Clutch Plate
Friction Plate AP
THE REST
Bypass hose Blanked
Points and ditributor
4 blade flan
Wire attached 13lb radiator cap!
Edited by liirge, 25 July 2010 - 08:10 PM.
#302 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 25 July 2010 - 06:25 PM
I like the sound of that spec but i'm not sure whether the 648 would be too much. Plus i think the final drive would absolutely do my nut in on the way to shows, ha. Bleeding and ears springs to mind, ha.
#303 liirge
liirge
  • 4,097 posts
Posted 25 July 2010 - 07:01 PM
FD would probably need changing, something like a 3.44 ('the mini ratio') will be well suited! 649 is not too bad.....I can get some figures for it if you like?
Edited by liirge, 25 July 2010 - 08:11 PM.
#304 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 25 July 2010 - 07:13 PM
Yeh if you don't mind mate. :D
#305 liirge
liirge
  • 4,097 posts
Posted 25 July 2010 - 07:34 PM
I'll get on that after Top Gear!
#306 liirge
liirge
  • 4,097 posts
Posted 25 July 2010 - 08:17 PM
Right so, its going to be a lot more cammy than the SW-10 that you were looking at, and I've got waiting to go into engine.
Valve Openings (Degrees)
Inlet 50
Exhaust 75
Valve Closings (Degrees)
Inlet 70
Exhaust 45
Duration
Inlet 300
Exhaust 300
Lift
Inlet 0.315
Exhaust 0.315
Rpm usage
3200 to 7500
Edited by liirge, 25 July 2010 - 08:19 PM.
#307 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 25 July 2010 - 08:32 PM
I think that'll be too cammy for me mate. I still want to be able to go to the shops and back without leaving 11's at every set of traffic lights, ha. Thanks for the info though bud :D.
#308 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 25 July 2010 - 09:32 PM
Why are engines so expensive ^_^. Just priced it up what i want and it's in excess of 1k :D. Didn't think it would be this much. It's not even massively spec'ed. Best get saving a bit more than i planned then ;).
Edited by AndrewJ530, 25 July 2010 - 09:32 PM.
#309 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 02 August 2010 - 10:12 PM
It's now looking increasingly likely that i'll have to sell this car now. I have nowhere to store it and this engine refurb is going to cost far more than i imagined.
Plus i'm moving to doncaster at the end of this month so i wont have any time to actually use the car :P.
So if anyone wants a tidy city E then send me a pm :D.
Andrew
#310 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 02 August 2010 - 10:20 PM
That's such a shame after you spent soooooooooo long looking for one.
Title is still wrong.
#311 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 02 August 2010 - 10:29 PM
Aye, took me bloody aaaaaaaaaaaaggggeeeeeeessssssssss to find this one and now it's already got a couple of blemishes.
Might think about getting a minus in the next couple of years and then no worries about rust, ha.
I'm never going to live this down am i ?!
#312 liirge
liirge
  • 4,097 posts
Posted 02 August 2010 - 11:37 PM
Nope never!! haha - nobody likes a quitter!!!! :D
A minus is cheating! :P
#313 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 04 August 2010 - 07:42 PM
It's not cheating...just bending the rules a little bit :D
#314 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 11 August 2010 - 08:08 PM
Okay, i've finally decided that i'm going to have to sell the car. I don't have anywhere to store it and i wont get any time to use with me having a new job in september.
So if anyone wants a tidy mini city e with 1 months tax and 7 months test for around the £1950 mark, drop me a pm >_<.
Edited by AndrewJ530, 11 August 2010 - 08:17 PM.
#315 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 12 August 2010 - 08:20 PM
My car is in the classifieds. Here's the ad:
http://www.theminifo...uct/14062/cat/7
Cheers,
Andrew
