Sports Arch Studs
8 replies to this topic
#1 tiganlea
tiganlea
  • 54 posts
  • Local Club: Nottsminiclub
Posted 20 June 2009 - 07:57 PM
bought some oe sportspack arches for my mini but some of the studs are missing.can you buy them and were from .????????
#2 nicksuth
nicksuth
  • 1,631 posts
Posted 20 June 2009 - 08:02 PM
Just replace some myself after an A panel replacement.
Bought some stainless steel flat pointed socket head grub screws that did the business - M5 x 20mm.
see http://www.stagonset.co.uk/
they also do the washered nut
#3 plantfitterRich
plantfitterRich
  • 316 posts
  • Local Club: not sure yet!
Posted 20 June 2009 - 08:03 PM
buy a length of 6mm studing and cut it down to length required. failing that just cut the head from some 6mm set screws (fully threaded bolts)
#4 nicksuth
nicksuth
  • 1,631 posts
Posted 20 June 2009 - 08:05 PM
But there 5mm i.e. M5 thread
#5 plantfitterRich
plantfitterRich
  • 316 posts
Posted 20 June 2009 - 08:07 PM
ok sorry 5mm!.... you get the idea though
#6 nicksuth
nicksuth
  • 1,631 posts
Posted 20 June 2009 - 08:13 PM
I was going to do the same and actually ordered a length of M5 studding but then found the socket head grub screws, it's a lot easier (and less damage) as you can use the allen key to insert them in the arch then just screw the washered nut over the top when the arch is fitted - "simples".
The OEM spostpack arches should have M5 threaded inserts sunk into them, if these are lost then you could bond them in with Araldite???
#7 tiganlea
tiganlea
  • 54 posts
great think i will go stainless .many thank for help
#8 tiganlea
tiganlea
  • 54 posts
Posted 20 June 2009 - 08:42 PM
have just orderded from the link you give me .the site is great plus can pay with paypal will use this link again many thanks again
Edited by tiganlea, 20 June 2009 - 08:43 PM.
#9 nicksuth
nicksuth
  • 1,631 posts
Posted 20 June 2009 - 08:48 PM
They are very quick with delivery as well, mine were delivered in 2 days (you'll probably get your's Tuesday with it being the weekend?)
I did get a bit carried away and bought all sorts of bits and peices for my stock, you can spend a fortune if your not carefull????
