Etch Primer Over Filler?
6 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 21 June 2009 - 06:09 PM
Hi
I am using U-POL Easy sand filler for a couple of repairs to my mini. I have got the area down to bare metal, and the area is now filled, smoothed down etc. I have a large area around the filler which is still bare metal.
Shall i use etch primer over the entire area, including the filled area? Or is this type of primer bad to use on filler, will it react etc?
I don't want to use two different primers if i have to, so any advice would be great.
John
#2 bmwalex
bmwalex
  • 397 posts
  • Local Club: Mini's With Attitude
Posted 21 June 2009 - 08:03 PM
etch primer everything did it 2 dai no problems
#3 jjojjas
jjojjas
  • 272 posts
Posted 21 June 2009 - 09:56 PM
what he says^^^^
thats what I did.
Jas
#4 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 22 June 2009 - 04:40 PM
This really depends on the Make of Etch you're using.... some specify that they cannot be used over filler whilst most specify the opposite. It would be best to read the manufacturers labels etc before commiting anything to a panel.
What is certain is that filler must not be applied ontop of Etch.
#5 mk=john
mk=john
  • 1,167 posts
Posted 22 June 2009 - 10:26 PM
Hi
Well, I have done as suggested by all here, filled, then used U-POL self etch primer over everything. Its seems to be OK, no problems so far. I will leave it for a while to be sure.
#6 Frog
Frog
  • 492 posts
  • Local Club: Blakehill Mini's
Posted 23 June 2009 - 08:05 AM
Hi
Yor shouldn't have any problems I have bare metalled a several shells, repiared all the dings & dents then etched, Primed & sprayed with no problems.
#7 jack_marshall
jack_marshall
  • 2,540 posts
Posted 23 June 2009 - 06:20 PM
1 dust coat over the lot no problem.
