Suck Vs Blow Through Setups
6 replies to this topic
#1 1275coopers
1275coopers
  • 23 posts
Posted 22 June 2009 - 01:07 PM
hi everyone, great site, great info.
Could someone please tell me if a suck through supercharger setup can be changed to become a blow through intercooled setup.
i have a jonspeed kit and am in the stage of making everything sweet before i put it on, but i am wondering if i should make it blow through so i can inter cool it or just leave it as a suck through setup?
thanks in advance!
#2 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 22 June 2009 - 03:45 PM
yes there is already a thread on here about blow through http://www.theminifo...howtopic=119379
but if you have already bought a kit i would use as is other wise you have to start again
#3 1275coopers
1275coopers
  • 23 posts
Posted 23 June 2009 - 08:37 AM
ok fair enough. thanks for the help.
one more thing, what clutch would you recomend for me to run? i got a 1310 cooper s motor. would a turbo clutch be the best??
#4 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 23 June 2009 - 04:51 PM
One more thing, what clutch would you recommend for me to run ? I've got a 1310 cooper s motor. Would a turbo clutch be the best ?
With or without the charger ? With the charger you'll need a grey diaphragm in there.
#5 1275coopers
1275coopers
  • 23 posts
Posted 23 June 2009 - 09:55 PM
yea, with the charger. grey diaphragm, ok. cheers for that. much appreciated.
Another thing, haha, sorry. What do i do about some of the breather points on the engine? for example the breather near the heater tap is going to be in the way of the pipe running from the charger to the carb. do i just block it off?( well it breathe enough then?) And what psi facet fuel pump is the best to use?
thanks a lot.
#6 Ethel
  • 26,073 posts
Posted 24 June 2009 - 12:29 AM
A suck through set up is just like a bigger engine as far as the carb is concerned. SU float valve's operate at 3psi.
Crankcase ventilation is always good, at the very least replace the can with a hose running to a catch tank.
#7 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 24 June 2009 - 06:43 AM
Put a decent sized breather in the rocker box to a catch tank if you're losing the cannister.
