Replacing Driveshaft Gaiter Inner
10 replies to this topic
#1 mini mayhem
mini mayhem
  • 307 posts
  • Local Club: Mini Club Of Ireland
Posted 22 June 2009 - 05:00 PM
ita a 1985 998 standard cv joints
metro turbo drive shafts
so what iv gathered from reading threads is that i can just bang off the the end with all the bearings??? it dosnt seem right but can someone clear this up for me please
i need to get the gaiter on. bearing end is left side(to diff)
Edited by mini mayhem, 22 June 2009 - 06:00 PM.
#2 mini mayhem
mini mayhem
  • 307 posts
Posted 22 June 2009 - 05:15 PM
:D anyone??
#3 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 22 June 2009 - 05:17 PM
Both ends have loads of ball Bearings, the Outer Joint can be smacked with a hammer to cause the Joint to come off the spring clip. The Inner joint should just pull out, it may come out with all its ball bearings,so dont loose any of them
Edited by liirge, 22 June 2009 - 05:17 PM.
#4 mini mayhem
mini mayhem
  • 307 posts
Posted 22 June 2009 - 05:20 PM
im on about the inner . im trying to put it back in but first im must fit a new gaiter. dose the end come off the shaft??
#5 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Posted 22 June 2009 - 05:44 PM
The centre part of the inner joint ball race fits over some splines on the driveshaft in the same way the outer cv joint slides on so to remove it you need to tap it off the splines,i found it easier to remove the whole shaft and clamp it in a vice as it was quite tight on the splines but other people may have had better luck!
#6 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 22 June 2009 - 05:51 PM
i ended up placing the shaft threw a brick and then hitting the shaft by the split to remove the inner pot joint was a bit of pain but worked well
#7 mini mayhem
mini mayhem
  • 307 posts
Posted 22 June 2009 - 06:08 PM
#8 tonic2k
tonic2k
  • 152 posts
Posted 22 June 2009 - 06:13 PM
peel back the gaiter thats on there and knock the joint with a hammer it will come off its splines remove the rubber thats on there slide your new rubber on and then refit the rubber thats on there now, then just knock thejoint back onto its splines
dont lose no ball bearings
#9 mini mayhem
mini mayhem
  • 307 posts
Posted 22 June 2009 - 06:21 PM
cheers tonic
#10 tonic2k
tonic2k
  • 152 posts
Posted 22 June 2009 - 06:23 PM
cheers tonic
no probs mate
#11 mini_turbo_pete
mini_turbo_pete
  • 1,101 posts
Posted 24 June 2009 - 01:40 AM
can you make things sound any more complicated?? you placed the shaft threw a brick and then hit the shaft to get the end off, i think you must have been sky high on drugs or something either that or your a *melon* that hasn't got a clue..
If you hold the shaft in in a vice and knock the inner joint off using a hammer, i would srongly advise the use of a copper mallet as opposed to a normal hammer as damage can occur to the joint if you use a normal hammer.
