Which oil should I put in my 1275mpi? The book says 10/30 but I live in Spain at the mo and cannot find it anywhere. Would 10/40 be ok?
Thanks for any help.
Edited by Cygnet45, 22 June 2009 - 09:24 PM.
Posted 22 June 2009 - 09:15 PM
Posted 22 June 2009 - 09:16 PM
Posted 22 June 2009 - 09:17 PM
Posted 22 June 2009 - 10:28 PM
Posted 22 June 2009 - 10:30 PM
I thought it was 10W40 for the MPi otherwise you bugga up the Oxygen Probe??
Posted 22 June 2009 - 10:33 PM
that seems to ring a bell, i think you are right
Posted 22 June 2009 - 10:34 PM
Posted 22 June 2009 - 10:37 PM
the man with a PHD on gearboxology
Posted 23 June 2009 - 12:15 PM
Posted 23 June 2009 - 01:47 PM
Posted 23 June 2009 - 02:08 PM
Posted 23 June 2009 - 02:19 PM
There was a write-up in mini mag a few months back stating that 20w50 has NO effect on the sensors of an MPi / Spi.
Remember kids the gearbox in an mpi/spi is identical to a carb'd one - you need thicker oil in the 'box or it will die a death!
Posted 23 June 2009 - 02:39 PM
Posted 24 June 2009 - 11:01 AM
the oxygen sensor strongly dislikes ZDDP and some other stuff in older oil. and yes, this gets burnt and reaches the sensor. the cat reacts the same
the viscosity has nothing to do with this, but the API classification.
and its a big myth that a gearbox needs thicker oil. ever seen gearbox oil? its very thin
Posted 24 June 2009 - 12:59 PM
no, as you can not realy compare the numbers.???? I always thought Gearbox Oil was of higher viscosity ???? Like the old Hypoid 90 and 140
