My Rolling Project
#166
Posted 19 April 2011 - 09:48 PM
#167
Posted 21 April 2011 - 07:15 PM
In for a penny..........
Soooooo,
I now have new pads, discs, hoses, seals, pistons, rear cylinders, and rear shoes, the more it was investigated the more was found,
Disc was warped and scorched
Pads (front OS) fried
Collapsed NS hose
Leaking rear cylinder
soaked rear shoes
Timing is out hence the 40mph on the hills. So that will be sorted on saturday.
And the welding, will now be done on monday, after the crappy effort I made on the sill, I am having it done properly.
#168
Posted 03 May 2011 - 07:07 PM
Broke down on the way there.
Bypass hose split.
Thanks to ben and chris all running and off to newquay, and back with no hiccups.
#169
Posted 03 May 2011 - 07:27 PM
#170
Posted 28 July 2011 - 09:02 PM
I am starting with a fresh clean subframe
New 1.5 negative bottom arms, (DELIVERED)
Polybushes all round (DELIVERED)
Refurb the top arms
New coil springs
clean up all the suspension and brakes,
General tidy up of the engine bay, and clean and paint anything that can be unbolted.
Hopefully ready for castle combe, then back in the workshop for the front end to be replaced.
Edited by mymini007, 29 July 2011 - 06:34 PM.
#171
Posted 30 July 2011 - 10:40 AM
New bottom arm pins
New bottom arm buffers
New top arm refurb kit
got the old sub frame stripped, so thats off to the powder coaters next week. The bottom arms are going to be painted as are the tops, once they are clean. The tie bars are also going to be painted in line with the Red white and blue theme.
#172
Posted 31 July 2011 - 03:28 PM
Very PatrioticJust ordered
New bottom arm pins
#173
Posted 31 July 2011 - 07:09 PM
Core plugs done
Pistons in
Crank in (although problems with the main shells)
Not a great deal of progress but its a start.
#174
Posted 03 August 2011 - 05:43 PM
i would highly recommend a new cam...
Chris
#175
Posted 03 August 2011 - 05:44 PM
are you rebuilding it as a standard 998 or are you doing any performance mods at the same time?
Chris
This is a 1275 we're building, with a special head.
#176
Posted 04 August 2011 - 07:54 PM
I have stripped the "spare" subframe tonight, this will be off to the powder coaters tomorrow.
Then I can start bolting on all my new shiny bits, I think I will be on first name terms at DNS classics by the time its finished.
Yes Chris its the 1275 I have had in my shed for about 3 years, stage 4 head, duplex timing gear, and it will end up with a bigger cam and a webber carb.
Edited by mymini007, 04 August 2011 - 07:55 PM.
#177
Posted 04 August 2011 - 08:19 PM
#178
Posted 07 August 2011 - 09:20 AM
Would not have been able to get this far so thanks to mini_mad69, still need more help though mate
Central oil pick up fitted,
Core plugs in, pistons and crank fitted, although due to buying the wrong shells, its currently on the old ones in this picture, also hence why the crank bolts are not tightened up so that will be a job for this week, to swap them over.
So far we have fitted new main bearings and bigends.
I have a second 1275 that I think I am going to just put it for now until this one is finished.
Some other bits arrived.
Edited by mymini007, 07 August 2011 - 09:42 AM.
#179
Posted 08 August 2011 - 10:49 PM
Got some pics but they did not come out will get some tommorrow.
#180
Posted 10 August 2011 - 06:19 AM
Engine out
Subframe out
I figure that if the engine is out I may as well replace the front end too, so started stripping all the other bits off too
I really need to cover the car if its going to sit outside
The old engine
The new one
