My Rolling Project
273 replies to this topic
#241 mymini007
mymini007
  • 2,046 posts
Posted 12 April 2012 - 05:24 PM
Just been shopping again
Thermostat bolts
Gear linkage bolt
Heater valve
Heater hose (temp till the samco arrives)
Engine steady
Dizzy - coil loom
Thats 3 trips to somerford this week, I am beginning to hate that place :lol:
Edited by mymini007, 12 April 2012 - 05:24 PM.
#242 mymini007
mymini007
  • 2,046 posts
Posted 12 April 2012 - 11:08 PM
Aaarrrrrrrgggghhhhh :goaway:
NOT HAPPY :angry:
5 steps back, off with the manifold, off with the carb.
Gear linkage was a total :xxx: :xxx: :xxx:
Biginning to this this bloody car does not want to be put back togther.
Edited by mymini007, 13 April 2012 - 08:13 AM.
#243 mymini007
mymini007
  • 2,046 posts
Posted 13 April 2012 - 08:45 AM
I think....its time to give up. There is no way this will be ready in time for the riv run >:(
Basically the chap who is helping me has lost interest and needs his ramps back, He keeps breaking stuff. Managed to snap a master cyclinder bolt last night. so I now have to take the pedal box out.
As well as the gear shift problem. I am about one more problem away from putting it on a trailer and scarpping the whole lot !
Edited by mymini007, 13 April 2012 - 08:48 AM.
#244 mymini007
mymini007
  • 2,046 posts
Posted 13 April 2012 - 04:53 PM
Right now I have had a chance to calm down, i am going back over to the workshop with my sensible head on and taking some back up with me.
I WILL have it running tonight!!!!
#245 mymini007
mymini007
  • 2,046 posts
Posted 13 April 2012 - 11:05 PM
No....I didnt have it running tonight, I was about 6 inches short - literally.
Managed to get the exhaust fully fitted.
the carb is back on, the rad hoses are on, the heater hoses are on - all bar 6 inches, the fuel pump is connected to to the carb, The thermostat is in and bolted up.
I need to get the slave cylinder sorted and the bolt for the master cylinder drilled out, connect up the remaining bit of hose for the heater, and move the coil so the loom from the dizzy reaches >_<
I think that is it!!!!!!!!!!
#246 mymini007
mymini007
  • 2,046 posts
Posted 19 April 2012 - 09:56 PM
Lost a few posts, so here is a brief recap
Slave cylinder on
Got all wired and plumbed in, exhaust on
Running briefly
Head gasket leaking, stinking of petrol, Ummmm, all a bit rubbish
Sooo,
Off with the head
Put some petrol in the bores to see if the rings were leaking.
All good, nothing leaking through, so cleaned it out and back on with the head
Tonight I got the rest back on, manifold, carb, all the plumbing back on.
Fired it up, ran it for about 15-20 minutes, all seems good, seems to run well, quite a bit of oil on the manifold so was a bit smokey and the exhaust was rattling and I can hear a leak so still a few bits to do
Its off to slarks on thursday for a rolling road session and mot, so the next few days will be bolting the lights back on and the other bits for the mot
#247 mymini007
mymini007
  • 2,046 posts
Posted 24 April 2012 - 08:32 PM
Rolling road has been put back to Tuesday, good job too as it took Brian1975 3 hours to get the clutch clevis pin in, tried to get the split pin in tonight and i just dont fit,
Try again tomorrow :goaway:
Got some primer on,
Bit more bodywork tomorrow, arches need to be cut and the side repeaters drilled.
#248 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 24 April 2012 - 10:21 PM
If you can't get the split pin in, use an R clip, much easier
#249 mymini007
mymini007
  • 2,046 posts
Posted 25 April 2012 - 08:49 AM
I have got an R clip, but I just cant fit my hands under the dash, got some very long nosed pliers to try again tonight
#250 mymini007
mymini007
  • 2,046 posts
Posted 25 April 2012 - 09:48 PM
New accelerator cable arrived today, so thats that fitted. :D
Still concerned about the gear linkage does not feel right.
Bled the clutch, got a new choke cable, but not fitted yet
Left to do
Dash fitting
Windscreen
Paint
Fit lights etc
test drive
Once its got the MOT, I need to fit the rear springs, so whilst all thats off I will shultz the rear arches.
Home straight now I think
Edited by mymini007, 25 April 2012 - 09:53 PM.
#251 mymini007
mymini007
  • 2,046 posts
Posted 29 April 2012 - 07:21 AM
Got the choke all connected up.
The gear linkage may have been solved but I still need to have a play, it seems rover made 2 different length gear linkages. This could be the cause of my problems.
#252 mymini007
mymini007
  • 2,046 posts
Posted 29 April 2012 - 06:28 PM
Suppose I had better go and take the gear linkage off then!?
#253 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 30 April 2012 - 08:32 AM
Remove gear lever, check that the push rod has not rotated 180 degrees. The cup that the ball on the end of the gear lever goes into should be at the bottom of the enclosure ie below the centre line of the push rod. If its located at the top remove the roll pin rotate 180 degrees and refit
Edited by ratty, 30 April 2012 - 08:32 AM.
#254 mymini007
mymini007
  • 2,046 posts
Posted 30 April 2012 - 08:48 AM
Thanks John,
That was the problem first time round, but still a problem, I have now decided that I think the linkage is too short, pre 92, and my subframe is Post 92. So I therefore need the longer linkage.
Pop to Somerford at lunch time to get the longer one, and try again, then maybe MOT this week - fingers crossed.
Edited by mymini007, 30 April 2012 - 08:48 AM.
#255 mymini007
mymini007
  • 2,046 posts
Posted 30 April 2012 - 10:18 AM
Just picked up the longer rods.
Bent the bold last night getting in out so got a new one of these, but got a nasty feeling I need to take the manifold off to get the bolt back in :unsure:
