MOT fail items for Feb 20 2010 Milage 71352
Offside Headlamp aim too high and too far to the right. (1.6) Brake pedal anti-slip provision missing (3.3.A.1b) Nearside Front Front wheel bearing has excessive play (2.5.A.3c) **DANGEROUS**
Brake master cylinder fluid level below minimum level (3.6.C.1e) Nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)
Drivers seat insecure (6.2.2) Front passenger seat insecure (6.2.2) Front Registration plate fitted to the front does not have black characters on a white background (6.3.2a) Rear Registration plate fitted to the rear does not have black characters on a yellow background (6.3.2b) Front Brake disc(s) excessively pitted (3.5.1h) Rear Exhaust has a mounting that it does not fully support the exhaust system (7.1.1b)
Offside Front Lower Radius arm has excessive play in a ball joint (2.4.G.3) Nearside Front Lower Shock absorber has an excessively worn rubber bush (2.7.4)
Offside Front Lower Shock absorber has an excessively worn rubber bush (2.7.4)
Exhaust emissions carbon monoxide content excessive (7.3.B.2a) Nearside low Rear brake application uneven (3.7.A.5c) Nearside Rear parking brake recording little or no effort (3.7.A.7a) Parking brake efficiency below requirements (3.7.A.9/10) **DANGEROUS** I have a spare wheel bearing in the garage, and some spare discs, and a spare exhaust, need to buy a new ball joint, not sure why the bushes have failed on the shocks, i put new shocks on less that 2000 miles ago.
Any way, will get this sorted and goive it a good service too.
Edited by mymini007, 04 May 2010 - 12:36 PM.
