Where Does The........
9 replies to this topic
#1 mattwho?
mattwho?
  • 844 posts
Posted 27 June 2009 - 10:51 AM
need to see the location of the water temp sensor as ive just got one to try and sort the petrol consuption out as its over fuleing
so i need a pic of where it is!!!
#2 Asphalt
Asphalt
  • 2,173 posts
Posted 27 June 2009 - 11:38 AM
What engine? Carb, SPI, MPI...?
#3 rocket powered
rocket powered
  • 61 posts
Posted 27 June 2009 - 12:18 PM
its on the side of the head, near number 1 plug , just below the thermostat housing
#4 mattwho?
mattwho?
  • 844 posts
Posted 27 June 2009 - 01:41 PM
spi and its on the inlet mani lol
#5 d4v1dtyler
d4v1dtyler
  • 314 posts
  • Local Club: CCMA
Posted 28 June 2009 - 05:49 PM
water temperature on the inlet manifold? lol
#6 mattwho?
mattwho?
  • 844 posts
Posted 28 June 2009 - 05:53 PM
lol yep funny aint it
had to buy a hains lol
#7 d4v1dtyler
d4v1dtyler
  • 314 posts
  • Local Club: CCMA
Posted 28 June 2009 - 09:07 PM
That will be air temperature i should imagine. You would be in trouble if you have water inside the inlet manifold.
#8 Pauly
Pauly
  • 4,213 posts
Posted 28 June 2009 - 09:10 PM
The coolent temp sensor is located in the underside of the inlet manifold, its heated (water) to aid cold starts.
Top replace it you need to remove the injector/inlet as its right underneath.
Paul.
Edited by Pauly, 28 June 2009 - 09:12 PM.
#9 Billy
Billy
  • 907 posts
Posted 28 June 2009 - 09:15 PM
Lol even funnier is if you gave enough info even I could of answered your question and I have never owned or worked on an spi :thumbsup:
#10 Pauly
Pauly
  • 4,213 posts
Posted 28 June 2009 - 09:18 PM
Overfueling could be your oxygen/lambda sensor failing, they are well known for failing on SPI's. Temp sensor fault I would of thought could cause rough running on cold and also your temp guage not working.
