Rolling Road Session!
14 replies to this topic
#1 eden7842
eden7842
  • 907 posts
Posted 28 June 2009 - 10:08 PM
hey
mine and mates mini went on a rolling road for the 1st time 2day.
ive got a 1275 metro
fast road cam
hif44
and rc40 exhaust
and it made 59.5 at the fly wheel, isent set up great tho. what do u think it should be doing. my next port of call is some head work and twin hs4's :thumbsup:
#2 mini mayhem
mini mayhem
  • 307 posts
  • Local Club: Mini Club Of Ireland
Posted 28 June 2009 - 10:10 PM
thats resonable enough power.. :thumbsup:
#3 eden7842
eden7842
  • 907 posts
Posted 28 June 2009 - 10:15 PM
this is good then :thumbsup:
i was a bit worried as i changed my head gasket about an hour before the run
the tester said it would have been a little higher but the wind own bit wasn't reading very well, if that makes sense
#4 newdawn1st
newdawn1st
  • 1,268 posts
  • Local Club: Fylde Mini Club
Posted 28 June 2009 - 10:59 PM
well I made 56 at the flywheel on a stage 1 998, so I would of thought you should make more :thumbsup:
#5 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 28 June 2009 - 11:06 PM
isn't set up great though
Where did you go for the session? - sounds like you need to Get you money back and go somewhere that knows what they're doing.
#6 joe_m
joe_m
  • 1,240 posts
Posted 28 June 2009 - 11:10 PM
Im with retro 10's on that one.. Unless you have one hell of a poorly engine
#7 Jonny998cc
Jonny998cc
  • 396 posts
Posted 28 June 2009 - 11:19 PM
it wasnt a rolling session it was just a power run, was only 25 quid so well worth it, dont worry he wasnt gettin taken for a ride.
the place was in quorn he said.
56 out of a stage 1 998 you say? no other mods atall?
cheers,
jonny
#8 newdawn1st
newdawn1st
  • 1,268 posts
Posted 28 June 2009 - 11:28 PM
Nope, only put 33 at the wheels tho, not too bad for running on 13's and a questionable gearbox :thumbsup: the RR guy said he believed there was a fast road cam in there but I'd put a question mark over that as I thought it was standard cam.
by the way as far as I'm aware a power run isn't wise if the engine isn't setup correctly in the first place, may cause damage. Only based on worrd of mouth tho, so I stand to be corrected.
#9 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 29 June 2009 - 08:12 AM
Ah i see- my mistake, the OP didn't didn't say it was just a power run so I wrongly assumed he'd gone to have the car set-up, which sounds like it's what it needs really. 59 at the fly is pretty low I would expect something closer to around 70 at the fly..
It is odd to do a power run without checking the car over and assessing the set-up - I take it he operator did a thorough examination pre-run?
#10 eden7842
eden7842
  • 907 posts
Posted 29 June 2009 - 03:18 PM
hey
opps should of said it wasn't a tuning session.
its was a last minute thing, spur of the moment jam it on there see what its putting out
regarding retro 10 now u mention it there was no check involved, my car is running poor, any suggestion on tuning? other than a rolling road session
as im planning a new head and twin carbs very soon, so would want to pay out then.
#11 joe_m
joe_m
  • 1,240 posts
Posted 29 June 2009 - 03:28 PM
Get the new engine bits done, tune it so it run's OK.
Run the head in abit.. shouldn't need too much but you know, then take it for a RR set up.
Correct me if i am wrong anyone?
Edited by joe_m, 29 June 2009 - 03:28 PM.
#12 1987_ParkLane
1987_ParkLane
  • 2,671 posts
  • Local Club: The Mini Forum
Posted 29 June 2009 - 03:51 PM
Hmmm sounds interesting, for that price, I know a few people who might want to go for a shootout out some point, and we are only in Melton Mworbay :) , so not that far away either.
#13 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 29 June 2009 - 04:11 PM
I'd recommend getting it set-up correctly before doing any sort of Modifications that improve performance. Modifications of this nature will often Make symptoms of incorrect running a lot more apparent - they can even flag up terminal problems with the engine... so it makes sense to know you've got a good engine that's set-up correctly before throwing go faster mods at it.
Leicester isn't that well placed in terms of mini specialists - but if you can bear the 1 hour drive then Southam Mini Metro Centre isn't that far.
For now I'd give it a darn good hard Service and see if that irons out any problems, Since you've done a power run - it would be adviseable to keep the graph they gave you, this will be a good indication to the next RR operator of what to expect, although different Rollers give different readings.
Any Operator worth their salt should give a car a check over before putting on the rollers especially on a bare power run. Walk away and find somewhere more reputable that know's Minis well
#14 Billy
Billy
  • 907 posts
Posted 29 June 2009 - 04:21 PM
I would be interested'ish in what my £50 metro lump pulls :)
so if you organise one give me a shout maybe we will see it die on the rollers Lol
Edited by Billy, 29 June 2009 - 04:21 PM.
#15 eden7842
eden7842
  • 907 posts
Posted 29 June 2009 - 05:39 PM
thanks retro 10 some good advice
and park lane and billy sounds like a grand plan so hopefully be in touch soon :)
