Synthetic Oil - Bad For Minis?
Posted 28 June 2009 - 10:10 PM
It is said -and this corresponds to my perhaps erroneous impression -
that synthetic oils tend to leak more .
Keith Calver in Minimag June 09 adds to the confusion by being ambiguous and subtly suggesting the use of
Torco oils - but which?
Posted 28 June 2009 - 10:12 PM
Posted 28 June 2009 - 10:14 PM
Posted 28 June 2009 - 10:59 PM
It may be ok for the engine but what about the gearbox? In almost every modern engine, the engine will use a completly different oil to the gearbox, as they are seperated components. Where as the mini/A series uses the same oil for both.
Posted 28 June 2009 - 11:44 PM
Posted 29 June 2009 - 08:01 AM
20w50 mineral is what I suggest (I use Halfords).
Paul.
Posted 29 June 2009 - 08:22 AM
Posted 29 June 2009 - 08:34 AM
Posted 29 June 2009 - 08:47 AM
Posted 29 June 2009 - 09:38 AM
Posted 29 June 2009 - 06:03 PM
Bearing in mind that this oil has the engine, gearbox and turbo to feed so oil changes have to be carried out religiously 6,000/6 monthly and I think that is the key. No matter what you use.. change it regularly
Posted 29 June 2009 - 06:22 PM
I have never been a big fan of 'halfrauds' cause they are well over priced in my opinion...
anyway...i found this in the 'moneyexpert' site : http://forums.moneys...d.html?t=265946
' We recently bought a 27 year old Land Rover which runs fine but is certainly not a fine tuned automobile. Consequentially we are not going to spend £10 a litre on Mobil 1 so we just want the cheap 20/50 basic engine oil.
Popped into Halfords where the only 20/50 oil they had was called 'Classic Car' oil and was very nicely packed in an old style metal can and was priced at £13 for 5 litres!!!
Anyway, went into Wilko's and they have 20/50 for £3.25 for 4.5 litres
Halfords the rip-off merchants are charging nearly 4 times the price just so you can have it in a nice tin. '
Just thought i would share what i found...as i thought, 'halfrauds' are over charging again!
Posted 29 June 2009 - 06:25 PM
Edited by redhotmini, 29 June 2009 - 06:27 PM.
Posted 29 June 2009 - 06:27 PM
I used to use Halfordsstuff until i went in there and the "helper" said they didnt stock it anymore as the mini was too old, so now i go to the local motor factors and pay £16 for something in a very similar tin - just cant remember the name!!
Posted 29 June 2009 - 06:28 PM
I always stick with millers 20w50 classic mini oil as the increased amount of zinc in the mixture quiets down the gearbox and runs very smoothy on it .
If u go on http://www.opieoils....661-20w-50.aspx you can order sikoline 20w50 classic oil which is good
theres gulf 20w50 too
lots of choice and they deliver so your sorted in the usa
they also do purator filters which are apparently 10% better than OEM filters
