Which Cam For A 1380
Posted 29 June 2009 - 09:53 PM
I know they use cams from the Piper range and I don't have much knowledge of their characteristics.
The car will be used for going around shows/classic runs but will also be using for the occasional sprint and hillclimb for fun not trophies (just don't want to look to slow).
The engine will run with a Stage 4 Brian Slark head and a 45 Weber, reading the spec sheets on Pipers site i am leaning towards the 285 which is fairly similar to Kent's 286 which I have used in the past.
Just wondering how lumpy at tick over is it likely to be and does it give an engine that is driveable and also has a bit of get up and go.
Rofert
Posted 30 June 2009 - 12:06 PM
Hi just looking for some general opinion, I am going to be ordering one of MED's Type R 1380's.
Rofert
Its horses for courses unfortunately, someones lumpy is someone elses racey if you know what i mean
If you have used a 286 before, what bore engine was it in? if it was a 1275/1293 or something standard, it will be more driveable in a 1380.
There is also the option of using a crank fired mappable ignition (megajolt or equiv.) meaning you can tailor your ignition curve to help cope with the lumpy idle. These also give you a few extra ponies and better fuel economy.
as for the piper range, im sorry i cant help, iv never driven one. There are a brazzilian threads about cam choices, i wouldnt be surprised if you found some info on pipers using the search... from memory, iv heard good things about the morspeed ph3, the sw5 and sw10 and the kent 286 and 296 and their scatter counterparts.
Posted 30 June 2009 - 12:17 PM
Posted 30 June 2009 - 12:53 PM
