There were only 3 wires that were cut to remove an old HU/radio plug, the purple, light green and the black. The new radio plug had to be connected and the only way was to cut. The radio is completely out of the equation now, not even hooked up, and all wires have been capped.
I have switched the flasher relay with a new one, that's not the problem, I assume, cause there was no change in the hazard lights, indicators, or interior light when tested.
I have left the hazard switch in it's original place, it has not been unplugged, EDITED: none of the wires are hot.
Where is the inline fuse for the purple "hot" wire? I have 4 inline fuses under the instrument cluster, and only 6 under the bonnet near the windscreen washer motor. Would it be in one of those locations? Since the purple/orange is hot when the hazard switch is in the off position I would assume it's not the inline fuse?
Also, is it possible a surge could take out the hazard switch, before it takes out some other fuse? I am going to test all my fuses and see if any are bad and not showing that they are blown.
Thanks again for all your help(s)
Edited by rathesungod, 05 July 2009 - 08:42 PM.
