Straight Cut Gearbox
Posted 06 July 2009 - 07:10 AM
[b]Year:1991
Help ive just had a straight cut gearbox put in my mini and it crunches going into second gear when changing down or if you dont get the revs up to 3 before changing from 1st gear. I tried to get mini sport to take it back and replace it but the wouldnt and it took them 7 months to deliever it in the first place. i replaced second gear but its still crunching. I was told by a garage that it was a trate of straight cut gear boxes. anyone else heard this? anyone know what i can do to fix this probelm.
Posted 06 July 2009 - 07:36 AM
What type of oil have you put in?
Replacing the gear itself is probably pointless, replacing the synchromesh (if it's not a dog box) could be the solution.
Posted 06 July 2009 - 07:37 AM
Posted 06 July 2009 - 07:58 AM
Quite simply, the baulkring on 2nd is knackered, if it was a new build from Minisport then ring them up.
Don't know the circumstances of the purchase, but as the consumer you are in the best position as you have received faulty goods.
Posted 06 July 2009 - 08:55 AM
If it is a dog box, then you should still only get crunching into first from stationary and then only sometimes ......
However if you are managing to get it to crunch in only 2nd then I would suggest that you have the more common 4 synchro (standard for 1991) type box..... in which case as above there is a fault that needs rectifying, be it at your cost or that of the supplier is upto you to chase.
Incidentally did you buy it as a second hand unit, or a rebuilt or new build etc...... what exactly did you purchase ?
Regards Martin
Edited by mra-minis.co.uk, 06 July 2009 - 08:56 AM.
Posted 08 July 2009 - 08:49 PM
Thank you for your help, yea its not a dog box, going to try and replace the sync soon and see if that works.
mini sport wernt interested when i rang them about the prob 3 times told me no gaurentee on a brand new straight cut gear box as its used for racing when they know from when i ordered it it was for a road carand built it to the spec of my car but then a again they wernt interested when they told me it would take 10 days to deliever and build and it took 7 months instead. think ill be sticking to mini spares from now on.
Edited by xCharlyx, 08 July 2009 - 08:51 PM.
Posted 09 July 2009 - 08:16 AM
Posted 09 July 2009 - 08:29 AM
1) Order information date etc..
2) Payment details and invoice
3) delivery information.... courier can help you if you haven't got that one
This will give you a good indictaion of the service you recieved and also the next steps available to you.
Regards Martin
Posted 09 July 2009 - 01:15 PM
Otherwise - it does sound like a faulty build - the straight cut box should change gear cleanly and without 'crunching' unless you are pulling it through ridiculously quickly!
