Fuel Breather Hose/charcoal Filter
11 replies to this topic
#1 m1tch
m1tch
  • 1,044 posts
Posted 07 July 2009 - 06:10 PM
Hi everyone, just wondering if that fuel breather hose and charcoal filter is needed, im pretty sure after 26 years of fumes the charcoal filter might be a bit saturated lol would it be ok to remove it? I guess I might need to put a breather filter onto the outlet on the carb? Or can I vent to air?
#2 goose the DJ
goose the DJ
  • 16 posts
Posted 21 July 2009 - 09:29 PM
Hmmm hi mate.
Is this the cylinder type metal casing that is on the end of a pipe coming from the carb that kind of blocks a screw of the float chamber?
We've just been down to cornwall in mags and noticed that when we had the windows open, we got overcome by fumes...
I was wondering what that cylinder thing is or does. If it is something to do with fumes being reduced...perhaps ours is knackered as well. ? .
I'll be interested to see what people reply mate.
Cheers for now.
Goose.
#3 newdawn1st
newdawn1st
  • 1,268 posts
  • Local Club: Fylde Mini Club
Posted 21 July 2009 - 09:40 PM
This may be worth a read, and apparently you can clean the breather in petrol once removed.
#4 Ethel
  • 25,932 posts
Posted 21 July 2009 - 09:49 PM
It's a different bit.
I don't know what the service life of the charcoal canister is, no doubt if it has one replacing it will be in the service schedule. It's also a closed loop system so even if the charcoal is long since defunct it will still gather fumes until they are fed to the inlet manifold
#5 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 21 July 2009 - 10:27 PM
Yeah you need them, I cleaned mine by soaking it in degreaser for a couple of hours, then ran a hose pipe through it for a little while. The outlet is 1/2" which is excact;y the same size as hosepiep.
They should then be connected to the engine, sometimes through the carb and sometimes into the air filter.
I personaly have removed all the inside of the canisters, looks a bit like rough wire wool when it comes out. I have then connected the cannisters into an oil catch tank which, will obviously catch any oil deposits, then this vents into the air filter to burn off any contaminated air.
Ben
#6 jmetal88
jmetal88
  • 289 posts
  • Local Club: okMini
Posted 22 July 2009 - 12:43 AM
Hmmm hi mate.
Cheers for now.
Goose.
Sounds like the tappet chest cover breather, if you're referring to the same canister I have on my car. I'm not exactly sure what letting the tappet chest breathe accomplishes (as I'm definitely no mechanic), but I deduced the name from this part description:
https://www.plminish...ct-12A1735.html
As well as this one:
http://www.minimania...2/InvDetail.cfm
And afterward was able to find the part here, you can check it and see if it's the part you were talking about:
http://minispares.co.....ITH BREATHE...
#7 goose the DJ
goose the DJ
  • 16 posts
Posted 22 July 2009 - 09:00 PM
http://minispares.co......ITH BREATHE...
[/quote]
hi mate. hmmm not sure its anything to do with i know as tappets. I have taken pickies but they wont upload onto here. email me at [email protected] and i'll ping the pickies to you.
#8 goose the DJ
goose the DJ
  • 16 posts
Posted 22 July 2009 - 09:02 PM
Hold on...just figured what you mean by the tappet chest cover...
this cylinder thing is far bigger than whats in those pictures...and from feel only, i dont think there is anything connecting the bottom of it to the tappet cover...
I'm doing the timing belt cover gsket this weekend, so rad coming out, and hopefully i'll get a better look at this bad boy.
will let you know. cheers. goose.
#9 goose the DJ
goose the DJ
  • 16 posts
Posted 23 July 2009 - 08:51 AM
These are the pickies of the unknown item gang.
Goose.
#10 Wil_h
Wil_h
  • 3,244 posts
Posted 23 July 2009 - 08:57 AM
What are you all on about, charcoal? filter?
What these are are flame traps, to stop any flames caused by backfires igniting the oil fumes in the sump. Inside, as noted, is a wire wool material, to my knowledge these never fill up and will last forever, cleaning the inside just seems pointless really.
If you have your breathers connected to the carb or airfilter, then you need to have the flame traps in place, if you are venting to a catch tank then you can chuck them in the bin.
#11 Ethel
  • 25,932 posts
Posted 23 July 2009 - 09:01 AM
Goose, that is an oil separator on the crankcase ventilation system. It's best left as it is. blow down the hose if you want to check if it's clear, the canister is just full off wire wool type stuff to trap oil droplets.
#12 goose the DJ
goose the DJ
  • 16 posts
Posted 23 July 2009 - 11:55 AM
Right ok mate, i wasnt gonna just take it off, i just wondered if it had a shelf life of less than 27 years...it'd be worth replacing it. But general word appears to be it'll be ok forever so i shall knock it off my list of theories into the fumes in the car.
Cheers mates.
Goose :wub:
