Over Reving
12 replies to this topic
#1 poulter78
poulter78
  • 19 posts
  • Local Club: north west mini club
Posted 09 July 2009 - 11:37 AM
mini mayfair
1991
Hi guys, I am new to the mini scene and after 20 years i have finally purchaced my first mini, i have been driving it around everywhere for the last 6 days having ultimate fun. Today i got in it, started her up no problem, after a couple of minutes it keeps reving up, the accelorator pedel is not stuck, and at first if i put my foot on the accelorator it would bring the revs down again but it is doing it all the time now and getting worse, can anyonre please help. thanx
#2 MiniMe01
MiniMe01
  • 88 posts
Posted 09 July 2009 - 11:39 AM
mini mayfair
1991
does it still rev realy funny when its just ticking over??
#3 m1tch
m1tch
  • 1,044 posts
Have you checked that the throttle cable hasn't got caught or frayed? I know mine decided to rev when it wasn't ment to as the cable was frayed and got caught in the plastic sleave
#4 poulter78
poulter78
  • 19 posts
Posted 09 July 2009 - 11:41 AM
mini mayfair
1991
Hi yes it revs when just ticking over but not as bad about 2000 rpm
#5 MiniMe01
MiniMe01
  • 88 posts
Posted 09 July 2009 - 11:43 AM
mini mayfair
1991
im not really sure because im not really good when it comes to technical things lol but it could be something to do with it trying to idle..if that makes sense
#6 Nelson92
Nelson92
  • 325 posts
Posted 09 July 2009 - 12:18 PM
hi that sounds like one of the cables is sticking. check that there's oil in the dashpot and that nothing's sticking in there. then get someone in the car to pull the choke out and push it in, then accelerate and then release (engine off by the way)
and watch for any cables getting caught or mechanisms not working.
take the big round airfilter off to do this for a better look.
a tiny spray of wd40 on any moving parts of the carb should solve this.
you should look into getting the haynes manual though as it covers how to do basic lubing.
if you're more mechanicaly minded get a carb refurb kit from mini spares and give it a rebuild.
Edited by kcholak, 09 July 2009 - 12:20 PM.
#7 mintom
mintom
  • 216 posts
  • Local Club: TVMC
Posted 09 July 2009 - 12:27 PM
Would agree on the cable being a strong contender, or something fouling it somewhere. There's a lot of lubrication in the throttle cable, for it to move very freely if it's at all sticky I'd replace it. the cable housing should be correctly fitting at the carb bracket and the bulkhead. When it's revving like that, put your foot under the throttle pedal and if you can pull it back up. Hopefully that's all it is.
#8 poulter78
poulter78
  • 19 posts
Posted 09 July 2009 - 12:32 PM
thanx so much for your help ill give it a try now
#9 Pauly
Pauly
  • 4,213 posts
Posted 09 July 2009 - 02:56 PM
Throttle return spring come off?
Paul.
Edited by Pauly, 09 July 2009 - 02:57 PM.
#10 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 09 July 2009 - 04:01 PM
Possibly throttle Cable has been moved, and melted on the Exhaust Manfold, i speak from experience on this one.
#11 poulter78
poulter78
  • 19 posts
Posted 09 July 2009 - 04:05 PM
nice one ill check it out
#12 bmcecosse
bmcecosse
  • 9,699 posts
Posted 09 July 2009 - 06:50 PM
Or poor earth return has melted the cable - as it tries to carry the starter current!
#13 jaydee
jaydee
  • 8,565 posts
Posted 09 July 2009 - 07:09 PM
Can be due to a sticking cable, but can be also a choke return spring worn and a jet blocked to a lower position.
Put you hand under the carb and try to push the jet up, and see if it goes up with a cluck. If so, there something wrong with you choke mechanism.
Another thing i'd check are air leaks. See that the vacuum pipe from servo to manifold is really tight, and spray some wd40 around manifolds, if engine revs slightly increase, you have an air leak at the manifold.
