Putting My Mini Shell On A `spit'
Posted 09 July 2009 - 01:52 PM
I am doing the final bit of welding to my 1960 mini....most of the restoration as far as welding has been done, I need to now do a bit of welding on the underside.
Anyway, I have a `spit' from M-machine, which has an A-frame at either end and the bar running through the speedo aperture and rear seat bulkhead aperture. This central bar sits in special brackets which clamp to the apertures.
The design of this does not allow the car to be locked at specfic angles......the shell can freely rotate. How difficult would it be for one person to rotate the shell so it is upside down? Also, what is the best way to lock it at cetain angles?
Any help on this would be great.
Posted 09 July 2009 - 02:01 PM
Posted 09 July 2009 - 06:47 PM
a). Stupid
and
b). Dangerous.
You need to fit a clamp or drill some holes in the collar and rotating part to take a pin in the same way that an axel stand takes a pin.
Posted 10 July 2009 - 08:47 PM
Posted 11 July 2009 - 09:49 PM
Hi, I succesfully put the car on the spit today, and followed your method of welding a nut to the top of each tobe, tightening with a bolt at the desired angle. It works really well, actually i can rotate the car myself really easily, and am also able to tighten the bolts.i drilled a hole in the top of the a frame where the pole goes through and welded a nut to it then put a bolt in get someone to turn the car to the desired angle and do the bolt up tight it holds it in place ive had no problems
Thanks for the help
John
Posted 12 July 2009 - 06:30 PM
good to here i hope it does the job for you glad i could offer some advice for a change instead of asking for itHi, I succesfully put the car on the spit today, and followed your method of welding a nut to the top of each tobe, tightening with a bolt at the desired angle. It works really well, actually i can rotate the car myself really easily, and am also able to tighten the bolts.i drilled a hole in the top of the a frame where the pole goes through and welded a nut to it then put a bolt in get someone to turn the car to the desired angle and do the bolt up tight it holds it in place ive had no problems
Thanks for the help
John
