Oil From Exhaust?
7 replies to this topic
#1 Stuboy
Stuboy
  • 26 posts
  • Local Club: PANDSMOC
Posted 10 July 2009 - 09:46 AM
Model: 1.3i Cooper
Year: '93
I replace my down pipe the other day, after fitting i was running the engine checking everything was done up tightly, no leaks, etc. I reved it a few times (it sounded different, rather nice!) and i noticed what looked like oil dripping out of the exhaust (tail pipe not any joints). If it was clear i wouldn't worry about it, just condensation... but this looks like and oily substance.
Could there be a problem with the piston rings or head gasket?
Cheers for any help.
Stu
#2 tangoedmini
tangoedmini
  • 186 posts
Posted 10 July 2009 - 09:49 AM
I had a similar problem on my 1275 when my head gaskets kept going, i would end up with the rear of the car sort of sprayed (lightly) in oil.
This soon stopped after replacing the head and head gasket.
#3 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 10 July 2009 - 09:51 AM
Hard to say what the problem is until you've identified what is dripping out. Condensation rarely drips out mini exhausts as it gets turned to steam - and if there is lots of condensation dripping out- it wont be clear as it it'll wash the carbon deposits out of the exhaust causing it to go black/brown.
Oil rarely gets into the exhaust for any other reasons other than worn piston rings or worn valve stem seals - in both cases it get's burnt off and exits in the form of blue smoke....
#4 Ethel
  • 26,130 posts
It could be from the exhaust itself: corrosion protection. If it's from the engine it can only really be from the exhaust valve stems or it would have been burnt.
#5 Stuboy
Stuboy
  • 26 posts
Posted 10 July 2009 - 10:10 AM
Thanks a lot guys, I'll have a closer look and see if it's slippery... perhaps its just dirty condensation... the car had been sitting for a week while i was waiting to replace the downpipe.
#6 m1tch
m1tch
  • 1,044 posts
Posted 10 July 2009 - 11:43 AM
I had a lot of rubbish come out my exhaust when I chucked some carb cleaner and it was running rich, perhaps it could be some condensation mixed with some carbon deposits?
#7 Pauly
Pauly
  • 4,213 posts
Posted 10 July 2009 - 12:38 PM
Are you sure its oil and not black coloured water? Might be running too rich and the liquid could be fuel?
Paul.
#8 m1tch
m1tch
  • 1,044 posts
Posted 10 July 2009 - 01:19 PM
Paul.
This senario would perhaps lead to flames...WOOOO :thumbsup:
