How Do I Raise Ride Height On My Front Suspension?
9 replies to this topic
#1 barney12482
barney12482
  • 34 posts
Posted 11 July 2009 - 02:54 PM
i have just got my first mini and recently put 5/12 superlight deep dish on, they rub the front wing when turning the steering, i have adjustable tie rods and adjustable bottom arms, the front end sits low and i have hi lows fitted, does anyone know how to adjust them?
i have adjusted the tie rod so they clear (just!!) but not sure thats the best result i can get.
any help would be great
#2 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 11 July 2009 - 07:39 PM
Welcome to the forum mate ;)
If you post this up in the tech section you'll get a more orientated reply, you could try the search aswell as I'm sure its been asked a few times already, just click my signature for any help?
Any pics of your mini?
#3 Purple Tom
Purple Tom
  • 4,921 posts
Posted 14 July 2009 - 03:42 PM
Moved to technical...
#4 CraigyBoy
CraigyBoy
  • 407 posts
Posted 14 July 2009 - 04:43 PM
The mini adjustable system is very simple, just undo the locknut on the upright, wind the fixed nut up how much you need, apply some copper grease then re-tighten the locknut. JOB DONE.
I would try to sort out you problem this way rather than adjusting the tie rod which will effect your castor and steering self centering effect.
Craig
#5 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 14 July 2009 - 04:50 PM
some more advice is you shouldnt just adjust you tie bars willnilly as this will have drastic effects in the handling and will need setting up properly in the future.
:) get some pictures up mate :dontgetit:
#6 Frog
Frog
  • 492 posts
  • Local Club: Blakehill Mini's
Posted 14 July 2009 - 05:25 PM
Have you cut the front edge of the wheels arch out to allow for the 5 1/2 x12's. Anything over 5x12 will need the arch modifying. Shouldn't go adjusting suspension set up to compensate.
#7 octagonalpaul
octagonalpaul
  • 353 posts
  • Local Club: shatrats.com
Posted 14 July 2009 - 05:52 PM
as said above, you need to cut out part of the wing for the wheels to have clearance. if you haven't already. If you just make it higher it'll scrub and catch when cornering hard or going over bumps.
#8 dight
dight
    Starting My Mini Up
  • 3 posts
Posted 26 November 2009 - 04:47 PM
[/quote]
Edited by dight, 26 November 2009 - 05:06 PM.
#9 dight
dight
    Starting My Mini Up
  • 3 posts
Posted 26 November 2009 - 04:58 PM
have same problem with 5x12's catching arches,
is there any adjustments i can make before i get the grinder out,as it's close to chrome arches aswell;
only need about an inch clearance,is there such a thing as spacer for suspension?
fitted wheels for missus'40th,got to get it sorted
cheers
dight
#10 dight
dight
    Starting My Mini Up
  • 3 posts
Posted 26 November 2009 - 05:00 PM
cheers
dight
