Wipers Sticking
6 replies to this topic
#1 newdawn1st
newdawn1st
  • 1,268 posts
  • Local Club: Fylde Mini Club
Posted 11 July 2009 - 06:43 PM
My wipers have been progressively getting worse, performance wise. Now they move any inch and stick, they do ok in the rain but if the screen is remotely dry, stick :)
The park switch is new, and today I removed the wiper motor and wheelboxes for a clean and light re-grease but no joy.
Any more suggestions? by the way did do a search thats why the re-grease and park switch ;)
Simon
#2 glyn
glyn
  • 637 posts
  • Local Club: leyland mini club
Posted 11 July 2009 - 06:50 PM
sounds like it could be your motor! if you have taken it all apart and greased everything up i think its the only thing left if you have checked the earth and all the wiring.
#3 newdawn1st
newdawn1st
  • 1,268 posts
Posted 11 July 2009 - 06:57 PM
Any test I can do? Multimeter type. Would it worth taking a bit of emery to the contacts in the motor? and as an aside how do mini wipers usually perform on dry glass, mine prior to this would usually go one sweep ok but needed washers on to come down.
#4 Gaffer
Gaffer
    Previously known as j519ldv. King of the spam costume!
  • 457 posts
  • Local Club: Crash Barrier Minis
I had this problem, only worked well off the screen or when the screen was wet, was corrosion on my earth contact in the park switch (motor side, not plug side) used a bit od scotchpad to clean it and the problem went away.
#5 newdawn1st
newdawn1st
  • 1,268 posts
Posted 11 July 2009 - 07:02 PM
will have a closer look at the earth side of things tomorrow :)
#6 Puddings
Puddings
    Nurburgring Master
  • 1,046 posts
  • Local Club: fabmoc/TMF
Posted 12 July 2009 - 04:09 PM
Sorry to jump in on your problem but my wipers wont stop working as soon as i turn the key they are on, i have replaced the park switch and the plug. speed changers but they wont turn off???
#7 newdawn1st
newdawn1st
  • 1,268 posts
Posted 12 July 2009 - 07:18 PM
I'd look at the stalk, seems its making contact all the time, might need the steering wheel of to get a proper look tho
