998 stage 2
Posted 18 September 2005 - 12:06 AM
Posted 18 September 2005 - 11:39 AM
Posted 18 September 2005 - 12:54 PM
Correct...Oct Mini Mag has a pretty comprehensive guide to all things 'Stage 1, 2, 3' with parts recommended.
Stage 2 normally comprises of a new cylinder head, and everything that is in a stage 1 kit
Posted 18 September 2005 - 01:44 PM
Err, thanks.Correct...Oct Mini Mag has a pretty comprehensive guide to all things 'Stage 1, 2, 3' with parts recommended.
Posted 18 September 2005 - 01:50 PM
Posted 18 September 2005 - 03:42 PM
Posted 18 September 2005 - 04:39 PM
Are you after a complete engine spec or just the head and cam?
Posted 18 September 2005 - 05:43 PM
Posted 18 September 2005 - 06:38 PM
998cc block Bored and honed to next size
Pocketed to accept a 12G940 cylinder head
Balanced and tuftrided crank
Balanced and shotpeened rods
Center main strap
12G940 Cylinder head
Ported and polished (Polishing not that important)
Chambers polished
1.3 Ratio Roller rockers
Depending on power output either a
HIF 44 Su carb or
Twin 1.25 inch SUs
Kent 276 cam or SW5 Swiftune cam
Venier timing chain (adjustable)
Aldon Yellow distributor
Id personally change to a non-verto clutch and flywheel so to have a range of upgrades but a verto should be fine for this spec
Stick to the original helical box with either a 3.44 diff or a 3.2 if motorways are to be used on a regular basis.
This lot shouldn't cost a fortune and I reckon would give a very nice lively car around town and when pushed on an open road would keep a smile on your face
Posted 18 September 2005 - 07:19 PM
Posted 18 September 2005 - 07:37 PM
There was an engine build in one of the Miniworld "Keep your mini alive" mags showing a decently tune 998 kicking out something between 80 to 90 bhp. Thats over a 100% increase.
Posted 18 September 2005 - 08:49 PM
Posted 22 September 2005 - 07:47 PM
Would this give a performance increase over the stage 1 kit and my standard 998cc head and also would it then be classed as a stage 2 kit?
Mike
