Converting Auto - Manual
4 replies to this topic
#1 zrblue
zrblue
  • 81 posts
Posted 12 July 2009 - 09:24 PM
Mini City E Autob]
1989
Hi all,
Basically, ive found a good mini, just passed its MOT for a bargain price. But its got a 998cc Auto engine. If i were to buy it, i plan to switch the engine out with a 1275 manual, or at the very least a 998cc manual. What involved in switching from auto to manual? Is it reasonably straight forward? Is there space for the manual linkage etc? Ive done engine swaps before on a Ford Ka, Rover 200, MG ZR, but ive not done a manual to auto. This would really be the deciding factor on whether to buy this mini or not.
[b]Is there a link to somewhere that i could find more info on this, or a list of parts ill need?
#2 tog77
tog77
  • 161 posts
  • Local Club: maun mini's
Posted 12 July 2009 - 09:33 PM
hi, there is quiet a lot of work to do it...i swopped the other way around..manual to automatic..so i i have all the manual parts needed to do it other than the pedal box...best if you picked up a 998 manual engine and gearbox unit.. then its all go..if you get stuck let me know.. bye the way,where are you.....
regards tog77...
#3 zrblue
zrblue
  • 81 posts
Posted 12 July 2009 - 09:51 PM
regards tog77...
Realistically, what sort of cost is involved in the conversion? Is it a matter of adding the clutch peddal and fitting the clutch cable, or do i have to remove all pedals and fit a new pedal box?
Im up near Edinburgh, infact, 7 miles west of where T in the park is going on just now.
#4 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 12 July 2009 - 10:58 PM
From auto to manual involves adding:
Clutch master cylinder + slave + hoses (the mini has a hydraulic clutch, not cable)
New pedal box
2x Spacers for the subframe (readily available from minispares)
Rod change Gearshift mechanism (or remote...)
Starter inhibitor wires need joining together (although you could modify this into a little security switch)
think that's all but might have missed something off....
Not that expensive to do really -
Is the automatic engine broken?> or do you just prefer manuals?
#5 Kerrin
Kerrin
  • 1,056 posts
  • Local Club: Manx Mini Register
Posted 13 July 2009 - 08:22 PM
Perhaps you can look out for a rotten MOT failure manual mini with a good engine and swap the engine, subframe, pedal box, gear selector rods etc over into your good car.
I have just bought an ex auto mini with an MG metro motor fitted, mine has spacers on the engine mounts as retro 10's mentioned above.
