Problems Sealing Exhaust @ Manifold
Posted 13 July 2009 - 04:40 PM
I have fitted a minispares RC40 exhaust. As I have retained the original cast manifold I bought the flanged downpipe also from minispares to mate this up.
I have been having problems getting the flanged connections to seal, so at my whits end I sent it to my local exhaust specialist. They have said that they cannot get it to seal properley either!
Has anyone else had this problem?
Thinking now of changing the exhaust manifold to a LCB item??
Posted 13 July 2009 - 04:46 PM
I have a 998 mini checkmate (1990)
On my OEM exhaust that flanged fixing was always leaking lol probably best to get an LCB anyhow as you will unlock some perfomance there
You tried some Holts firegum in the mean time?
Edited by m1tch, 13 July 2009 - 04:46 PM.
Posted 13 July 2009 - 05:08 PM
Could try the firegum but to be honest I hate that stuff - rather get it sealed without if I could.
Posted 13 July 2009 - 05:40 PM
Hmmm seems it might have to be the LCB. I had heard about the new inlet manifold - makes it a dear do!
Technically you don't need to get a new inlet manifold, but you might as well lol check out ebay for some deals and also the classified section of this forum
Posted 13 July 2009 - 07:48 PM
Even the inlet manifold will require a bit of trimming because lcb flanges have different thickness. Cooper freeflow usually fits 'bolt on'.
Posted 14 July 2009 - 10:35 AM
LCB's are pesky - the cooper freeflow will fit straight on and doesn't have that terrible Y-piece to contend with or the seperate center branch.
Posted 14 July 2009 - 11:49 AM
1) Undo exhaust bracket on gearbox.
2) Wack jack under exhaust.
3) Jack up so the two flanges are together ... try not to bend the exhaust.
4) Take a load of exhaust goop (sealant) and put it around the flanges (put a glove on, stick gloop on hand then rub)
5) Put some inside the clip as well.
6) Bolt together and let it sit for a min, then do the gearbox clip up again.
7) Hope it works.
Thats what I did, seemed to work fine.
Posted 14 July 2009 - 05:10 PM
Picked the car up today - exhaust still not sealed so just spoke to minispares and going to order the following;-
Maniflow cooper exhaust manifold C-STR816
Inlet manifold C-AHT770
£100 for the 2 but I am fed up with this now. Garage were great and didnt charge me for all the messing they did.
Mini failed its mot on exhaust plus nearside handbrake plus stearing rack gaitor.
Not bad as the car has been off road for 4 years!
