Low Washer Jet Pressure
Posted 16 July 2009 - 01:06 AM
Posted 16 July 2009 - 01:29 AM
Posted 16 July 2009 - 11:24 PM
I have fitted some chrome ones, but even with the black standard ones on the car, the water just got to the screen. Is there a pump that I can check?
Posted 17 July 2009 - 08:31 AM
They're not blocked.
The pump is located on the actual washer bottle on the driver side, perhaps the contacts are corroded or the pump has failed?
Posted 17 July 2009 - 08:50 AM
Posted 17 July 2009 - 09:13 AM
if it's a 1998 car, the washer bottle should be on the boot. As said, the pump itself attached on the washer bottle.
Ah ok lol im not used to these new fangled classic minis
Posted 17 July 2009 - 09:31 AM
Posted 17 July 2009 - 10:07 AM
So in instead of pumping water through 1-1.5m of tube it has to do 3-4m worth of tube.
The pump is inadiquate!
It's the same on my 98 Mpi, like you I have twin chrome jets, the water does reach the windscreen O.K but with no great pressure.
If you've chacked for leaks and bends like I have, I think we'll have to either replace the pump with a different one or put up with it.
Posted 17 July 2009 - 11:28 AM
Can check all the pipework too, might have a kink or a blockage, possible one way valve has gone duff too - thats by the washer bottle.
The one way valve was my first thought too. You can pick them up for pence from motor factors.
