I am just waiting for my new fuse box to show up through the postal service and am getting ready to put it in.
I am getting rid of the old glass fuses that are a total PITA and putting in a new fresh ATC blade fuse box.
The problem I have is, I do not know the original sizes of the fuses since they have more then rusted over the stamping.
From the top down on the box there are 4 glass fuses and some have more then one connection. I will be breaking the multiple connection ones out to their own circuit for a fuse when I put it all back together.
Does anyone know the size (AMP) of the fuses that run down the box so I can atleast start at something close for them?
Any non-standard parts that might be involved with the problem?
Fuse Sizes For Factory Box.
DrMcNasty
, Jul 16 2009 05:14 PM
4 replies to this topic
Posted 16 July 2009 - 05:14 PM
Posted 16 July 2009 - 05:17 PM
i beleive it is
35
25
15
15... not sure on he last two as i dnt have a haynes to hand...
i know its defo
35
25
15...
35
25
15
i know its defo
35
25
15...
Edited by mini_mad_daps, 16 July 2009 - 05:18 PM.
Posted 16 July 2009 - 05:24 PM
Are they listed in the Haynes somewhere?
I couldn't find them in mine but in my defense, I was a little frazzled from hunting gremlins.
Posted 16 July 2009 - 05:46 PM
They go:
35
25
25
15:
Main fuses (four-fuse fuse block - later models)
Fuse connecting Rating (amp) Circuits protected
1 and 2 35 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Stop lights, reversing lights, direction indicator relay, heated rear window, headlight dim-dip relay. These systems will only operate with the ignition switch at position ll
3 and 4 25 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Horn, headlight flasher, brake failure circuit, radio memory. These systems operate independently of the ignition switch
5 and 6 25 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Heater blower motor, windscreen wipers/ washers, instruments. These systems will operate with the ignition switch at position I or ll
7 and 8 15 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Left-hand
Can be found at start of section 12 " body electrical system"
HTH
Ryan.
35
25
25
15:
HTH
Ryan.
Posted 16 July 2009 - 06:00 PM
Perfect! Thank you.
