Ram Pipes?
15 replies to this topic
#1 Burnard
Burnard
  • 3,350 posts
Posted 18 July 2009 - 05:04 PM
Hey,
First off, will fitting a ram pipe give me more power than just fitting a K&N filter (this type) ?
And on a stage one 998 which would i need, a long or short one?
And will i need to modify my bulk head to get it to fit and allow clearence for the pipe and air flow?
And one semi related question, Which needle is needed on a 998 with a stage one kit?
I havent actually bought any of it yet, but i will be buying maniflow parts so it wont be a kit.
Chris
#2 Figs122uk
Figs122uk
  • 823 posts
Posted 18 July 2009 - 05:06 PM
Chris
I can tell you its an AAM needle that you'll be needing...
See here: http://www.theminifo...x...30305&st=15
#3 m1tch
m1tch
  • 1,044 posts
Posted 18 July 2009 - 05:39 PM
My stage 1 kit is running an AAA, some kits come with an AAU or an AAV needle, need to be rolling roaded to get the optimum power >_<
As for the rampipe/K and N filter, you will need both, a carb doesn't like a 90 degree bend as it messes with the air flow, that ramstack should go inside the K and N filter (im assuming that its a stubstack)
That K and N filter will fit any Mini, its only the pancake style ones that have clearance issues on the centre speedo minis (like mine) due to the speedo cable being there.
#4 jaydee
jaydee
  • 8,565 posts
Posted 18 July 2009 - 05:43 PM
Yes a ram pipe will help, but you need a short one or the filter will be too close to the bulkhead, if not hitting thou.
About needles, AAM or AAA will be good.
#5 Figs122uk
Figs122uk
  • 823 posts
Posted 18 July 2009 - 05:48 PM
can you get these AAM needles from ebay? because i cont seam to find any on there....
#6 m1tch
m1tch
  • 1,044 posts
Posted 18 July 2009 - 05:55 PM
I did see some on ebay a bit back when I was looking for mine, but its probably easier to go on minispares to get it, which is where I got mine from as well >_<
AAM:
http://www.minispare...?ty=... (AAM)H...
AAU - supplied in their stage 1 kits
http://www.minispare....WINGING,STAGE...
AAA- what I, and many other are running
http://www.minispare...ty=pb&pid=37492
Also check out this online app to check the difference between the needles (AAM seems to be twice the price of the AAU or AAA lol):
http://www.mintylamb.co.uk/suneedle/
Edited by m1tch, 18 July 2009 - 05:58 PM.
#7 Figs122uk
Figs122uk
  • 823 posts
Posted 18 July 2009 - 05:56 PM
I did see some on ebay a bit back when I was looking for mine, but its probably easier to go on minispares to get it, which is where I got mine from as well :teehee:
I cant get to minispares now though till 2 weeks yesterday.... >_<
#8 m1tch
m1tch
  • 1,044 posts
Posted 18 July 2009 - 06:00 PM
The AAM needle is only slightly richer than the AAA, so perhaps find an AAA as they seem to be cheaper >_<
#9 Cooperman
  • 23,294 posts
Posted 18 July 2009 - 06:01 PM
You won't notice much difference with or without a ram pipe. On my 1293 rally Cooper 's', it gained about 1.5 bhp at 6400 when the stub-stack ram pipes were fitted inside the K & N filters. I was quite disappointed. Maybe if 3" long, or longer, ram pipes were fitted the improvement would be more noticeable. I can't say they improved mid-range torque either, but my car is so 'cammy' I possibly wouldn't notice anyway.
Put it this way, it can't hurt to fit them.
As for needles, the expression 'Stage 1', really doesn't mean very much. It's a widely mis-used term for a minor set of tuning mods which differ from one 'stage 1' supplier to another. It would be more help to you to call a rolling road company, like Peter Baldwin, give them the actual specification, not just 'stage 1', and ask for their advice. That will get it running, then you need a rolling road session to set it up accurately.
#10 Burnard
Burnard
  • 3,350 posts
Posted 18 July 2009 - 09:03 PM
Tell me if ive got this right...
I will need to modify my bulkhead to allow a ram pipe to fit and get enough air flow, and i will need a long one?
This wont be much of an issue i think. from what i can see the ram pipe would just go straight through the existing hole which is coverd by a plastic blanking plate, which i could replace with a home made version.
And im best off phoneing a rolling road place for the needle advice?
I know a ram pipe needs a filter i think they call it a sock.
I was asking if i would get better performance from a ram pipe set up instead of just the normal cone filter that most people use.
Thanks for the help guys.
Chris
#11 jaydee
jaydee
  • 8,565 posts
Posted 18 July 2009 - 10:09 PM
Yes the original ram pipes gonna be used with a sock filter.
You dont need to modify bulkhead to fit that kind of rampipe, for HS4 carb they are 2,5" long.
You need more clearance if you want to fit a long 'stub stack' rampipe for a K&N cone, but, as above said, you can even fit the stub stacks inside the filter, then u'll have no issue at all.
Edited by jaydee, 18 July 2009 - 10:12 PM.
#12 m1tch
m1tch
  • 1,044 posts
Posted 18 July 2009 - 10:12 PM
Its only really when you heavily upgrade the carbs to say a Weber will you need a bulkhead box, simply to fit the larger inlet manifold, fitting ramstacks won't need any modification :lol:
#13 jaydee
jaydee
  • 8,565 posts
Posted 18 July 2009 - 10:20 PM
Actually the problem is that there isnt such a good airflow near so close to the bulkhead, thats why many of us are using an airbox casing or an a long air intake to route airflow from the front grille to the air filter.
#14 Burnard
Burnard
  • 3,350 posts
Posted 18 July 2009 - 10:31 PM
Can you explain that a bit better please, i dont quite understand what your saying :lol:
Chris
#15 jaydee
jaydee
  • 8,565 posts
Posted 18 July 2009 - 10:58 PM
Oh you're right. You can even use a longer stubstack which fits inside the cone filter, and theres no need to modify bulkhead, thats what i mean. Sorry its bit late and i'm old..
Edited by jaydee, 18 July 2009 - 11:00 PM.
