Camshaft Pulley Nut/bolt
10 replies to this topic
#1 mrbridger
mrbridger
  • 422 posts
  • Local Club: no
Posted 20 July 2009 - 03:12 PM
1980 mini 1000.
I'm intending to replace the timing chain and I have spent ALL day trying to loosen/remove the camshaft pulley nut.
I followed Haynes guidance and put the car in fourth gear and applied the handbrake. I also chocked the wheels.
The problem is that i can't see a way of preventing the pulley from rotating with the nut.
I've wedged all kinds of tools and wood blocks under the pulley to no avail.
There isn't enough space between the nut and the inner wing to use my air impact wrench.
Before i go out and buy an air ratchet, is there a trick i'm missing?
Andy
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 20 July 2009 - 03:13 PM
when you say in 4th gear etc? is the car and both front wheels on the ground......
#3 mrbridger
mrbridger
  • 422 posts
  • Local Club: no
Posted 20 July 2009 - 03:22 PM
yes, all four wheels on the ground. Haynes says top gear and handbrake on.
#4 lrostoke
lrostoke
  • 6,923 posts
Posted 20 July 2009 - 03:25 PM
Obviously daft question but you did knock back the locking tab.
Also try shocking it off...put the socket on then try giving the handle of the bar a good wack.
If you removed the radiator you should be able to get a couple of socket extensions on and use the air gun through the wing slots. In fact should be enough room get your air gun in at it without extensions.
Edited by lrostoke, 20 July 2009 - 03:26 PM.
#5 Grayedout
Grayedout
  • 901 posts
Posted 20 July 2009 - 05:24 PM
Just take the starter motor out (2 bolts) and then get a friend to jam the flywheel with a hefty screwdriver!
#6 Cooperman
  • 23,330 posts
Posted 20 July 2009 - 07:06 PM
You need the flywheel locking tool which bolts on where the starter motor bolts go.
If you set the timing marks correctly with 1 & 4 at TDC before locking the crank, it's so easy to fit the new chain at the correct timing.
Undo the lock tab and use either a flat open-ended spanner or a flat ring spanner to undo the cam nut.
#7 mrbridger
mrbridger
  • 422 posts
  • Local Club: no
Posted 20 July 2009 - 07:51 PM
Thanks everyone for the tips.
I took the passenger side front wheel off and managed to get a socket onto the nut and fed and extension bar through the letterbox shaped hole in the inner wing.
Even with the use of the impact wrench, the nut wouldn't spin. The wrench just seemed to rattle the socket against the nut.(And my fillings rattled in my teeth!)
I think i'll invest in a flywheel locking tool and have a go with that.
If that doesn't work I'm going to have to hand the job over to a local garage.
I hate the idea of leaving a car i've looked after done loads of work on with someone who may jack it up under the floor pans or lean on the wings with paint scratching buttons down the front of their overalls.
What, me, paranoid?...
#8 Grayedout
Grayedout
  • 901 posts
Posted 20 July 2009 - 08:26 PM
You don't need the flywheel locking tool !! Just a big flat bladed screwdriver will be plenty !!!! The torque on the pulley nut is not huge !
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 21 July 2009 - 12:40 AM
My first thought was also the lock tabs. Not trying to insult you with this suggestion either.... This is a standard nut, you are turning counterclockwise to loosen aren't you?
There should not be so much torque on that nut that you should need more than 4th gear with all four wheels on the ground.
#10 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 21 July 2009 - 08:23 AM
Ive always used a screwdriver or Very thin Spanner between the teeth to lock the flywheel!
#11 GraemeC
GraemeC
  • 7,440 posts
Posted 21 July 2009 - 08:32 AM
An old shell bearing makes and ideal flywheel locking tool :thumbsup:
