I remeber seeing an artical a little while ago in one of the mini mags where canems installed a mpi injection system into a 998 useing mostly mini parts and then their ecu.
Has anyone tryed this conversion? i currently have the mpi throttle bodies and fuel rail bits, i know i will need a coil and a trigger wheel + sensor, a MAP gauge but what about fueling, can i use a aftermarket facet pump so i dont need a return line to the tank? or will i still need this??
oh and by replying to this topic with "yes ive done this conversion" expect lots more questions your way
thanks all
(not sure if this should be in the injection section or not)
